jgeck90 7 Posted March 20, 2013 Hello, i recently upgraded to Corel X6. Here is what happens when i try to simply export to Signcut. I had X5 before and never had an issue. I could design something and export straight to Signcut and save it as a SC file and i wouldn't save it at all in Corel Draw. Any help would be appreciated. Share this post Link to post Share on other sites
knucklehead 530 Posted March 20, 2013 Are you using the 'launcher'? Share this post Link to post Share on other sites
jgeck90 7 Posted March 21, 2013 Thanks for your reply. What is the launcher? I tried to export and tried saving and opening it in sign cut but still get the error. Share this post Link to post Share on other sites
knucklehead 530 Posted March 22, 2013 It's the 'application launcher', right under text on the top bar. Has a little red thing on the bottom of it. Click on it, and your cutting software should be in the drop down menu. Click signcut, and the image should open directly into signcut. If that don't work, try save, export as an eps, then 'import' into signcut. Share this post Link to post Share on other sites
d5kerry 25 Posted March 22, 2013 Have you tried to save as an Ai file? Share this post Link to post Share on other sites
jgeck90 7 Posted March 23, 2013 Here's a video of my issues. http://www.youtube.com/watch?v=liw619IdhhU&feature=youtu.be Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 23, 2013 is that problem just on that file or all files? post the file, see if there is a problem that your not seeing.. Share this post Link to post Share on other sites
jgeck90 7 Posted March 23, 2013 Everything. I import it as a JPEG. I have no clue why it says something about PDF. Share this post Link to post Share on other sites
d5kerry 25 Posted March 23, 2013 Why do you click bitmap, mode, black and white, line drawing? You can go straight to trace, low quality image, and its done. Share this post Link to post Share on other sites
jgeck90 7 Posted March 23, 2013 Why do you click bitmap, mode, black and white, line drawing? You can go straight to trace, low quality image, and its done. It's just a habbit since most of my stuff is in color when i import it to Corel. This also has nothing to do with my question. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 23, 2013 Everything. I import it as a JPEG. I have no clue why it says something about PDF. I meant post the vector file you created... the jpeg file won't help... if you can post the vector file we can see if it is a good cuttable file... Share this post Link to post Share on other sites
d5kerry 25 Posted March 23, 2013 Well i does have something to do with your question. You are putting in an unnecessary step into the process, i was trying to eliminate the problem but you obviously know better. It's just a habbit since most of my stuff is in color when i import it to Corel. This also has nothing to do with my question. 1 Share this post Link to post Share on other sites
jgeck90 7 Posted March 24, 2013 Making it black and white wouldn't have anything to do with exporting is what i was trying to get at. Wasn't trying to sound like a dick......... Share this post Link to post Share on other sites
