EclecticGrafix 2 Posted August 23, 2012 Hello and thank you ahead of time. I've been using my GCC Expert 24 to cut vinyl airbrush stencils (Oracal 810) for about a year. Just started making decal recently. I use Corel X5 as my graphics platform but I only have a basic grasp on it so far. I've learned more here on 5 days than I was able to accidently teach myself in a year. Again thanks Chuck Share this post Link to post Share on other sites
BannerJohn 1,324 Posted August 23, 2012 welcome! What part of Virginia? Share this post Link to post Share on other sites
mountaindr3wz 0 Posted August 23, 2012 Welcome from San Diego, Ca! For cutting the airbrush stencil, how well is the adhesion property? Are you able to remove it and reapply to a different area if needed? I've always wanted to try cutting a stencil out. Thanks! Share this post Link to post Share on other sites
Jay2703 704 Posted August 23, 2012 Welcome from the great northwest. 1 Share this post Link to post Share on other sites
MooreEmergency 4 Posted August 23, 2012 Welcome for Southeastern Va. Where about are you located? Share this post Link to post Share on other sites
EclecticGrafix 2 Posted August 23, 2012 For cutting the airbrush stencil, how well is the adhesion property? Are you able to remove it and reapply to a different area if needed? I've always wanted to try cutting a stencil out. Thanks! The Oracal 810 is "low tack" so it won't lift paint when the stencil is removed. So far I've never had a problem with it. I've used it on all kinds of surfaces and textures with no issue. As long as it doesn't get dirty when you apply it you can pick it up and move or adjust it with no issue. it cuts and weeds the same as any other vinyl. Share this post Link to post Share on other sites
EclecticGrafix 2 Posted August 23, 2012 Welcome for Southeastern Va. Where about are you located? I'm in the Lake Anna area just south of Fredericksburg. Share this post Link to post Share on other sites
Lady_VI 45 Posted August 23, 2012 Hello and Welcome Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted August 23, 2012 Hello and welcome from West Virginia Dan Share this post Link to post Share on other sites
Sue2 920 Posted August 25, 2012 Hello and welcome from the "tip top of Virginia"...a stones throw from WV! Sue2 Share this post Link to post Share on other sites
rlvied 292 Posted August 25, 2012 Hello and welcome from Delaware Bob Share this post Link to post Share on other sites
DLA1234 2 Posted August 28, 2012 Hello and welcome from the Richmond area (just south of Richmond) Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted August 29, 2012 Hello and welcome from the "tip top of Virginia"...a stones throw from WV! Sue2 You close to Unger WV. ? Share this post Link to post Share on other sites
Sue2 920 Posted August 29, 2012 You close to Unger WV. ? You close to Unger WV. ? Winchester close enough? Sue2 Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted August 30, 2012 Yep I live in southern WV. But travel Va. And WV. A lot have been there many times have done signage in martinsburg WV Charles town and all thru that area. Share this post Link to post Share on other sites
