Double A 6 Posted May 1, 2012 Trying to do some wall art/lettering but my transfer tape is to tacky and won't let the letters release. What are some of your suggestions that I should use? Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted May 1, 2012 UScutter has transfer tape for Oracal 631 vinyl. http://www.uscutter....e+for+631+Vinyl Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted May 1, 2012 A trick is to de-sticky the tape . Just put it on a cloth or pant leg then apply it to your vinyl, makes the tape less sticky. You can also add heat to it to help separate the two. Share this post Link to post Share on other sites
Coaster36 327 Posted May 1, 2012 Or dappen the transfer tape. A sprits with a water bottle or a couple wipes with a wet towel should do the trick. Share this post Link to post Share on other sites
Double A 6 Posted May 1, 2012 Thanks for the help and suggestions I'll give those a try Share this post Link to post Share on other sites
vinylmotivations 143 Posted May 2, 2012 What tape are you using??? I use 4075RLA from R-Tape/FDC- I was originally given 4076 which is SUPER high tack... Share this post Link to post Share on other sites
Double A 6 Posted May 4, 2012 I have these two http://www.uscutter.com/GreenStar-Layflat-Classic-Transfer-Tape-Assorted-Widths-B-UCSTAPE http://www.uscutter.com/GreenStar-Layflat-Clear-Transfer-Tape-Assorted-Widths-B-UCSTAPECLR But havent had a chance to try any f the methods above Share this post Link to post Share on other sites
markvvq 14 Posted May 4, 2012 A big problem is getting the vinyl to stick to your wall. Mark Share this post Link to post Share on other sites
Double A 6 Posted May 4, 2012 So did I waste my money then on oracal 631? Or what are my options tog et it to stick Share this post Link to post Share on other sites
vinylmotivations 143 Posted May 4, 2012 NO NO... O631 is designed for walls... your tape is too tacky. I am sorry but to put it bluntly the greenstar app tape is just not as good as the rtape or others. You get what you pay for. Get some good RLA4075 or comparable and you will be MUCH happier. Share this post Link to post Share on other sites
Double A 6 Posted May 4, 2012 Where do you buy that app tape? I don't see it in uscutter Ever used that Ht55 used for vinyl 631 app tape? Thanks for the help need help with this wall art stuff Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted May 4, 2012 this tape? http://www.uscutter.com/RTape-ApliTape-4075-High-tack-General-Purpose-Application-Tape-100yd-RTT4075 Share this post Link to post Share on other sites
Double A 6 Posted May 4, 2012 But that's another high tack tape and is Rtt4075 So not sure if that's the same stuff Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted May 4, 2012 Yes it is. I used to use Rtape 4050 medium tack,on regular sign vinyl. purchased elsewhere, but have never used Oracal 631 Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted May 4, 2012 But the HT55 is made by Oracal for Oracal 631 Share this post Link to post Share on other sites
Double A 6 Posted May 5, 2012 Do you guys have a suggestion on blades my cutter seems to peel the vinyl up as it cuts using the 631 Share this post Link to post Share on other sites
vinylmotivations 143 Posted May 5, 2012 I use all 45' blades for my 631 and my 651.... What speed and pressure you using??? I usually have my graphtec's condition set on step 14 (pressure) or so for 631, speed of 6-10 and quality of 1 (acceleration) Share this post Link to post Share on other sites
Double A 6 Posted May 5, 2012 i have a uscutter Mh series (hoping to upgrade soon) but i lowerd the speed to 70 and the cutpress was at 190. What cutpress would you recomend? and the up speed is at 380mm/s and baud rate at 9600. recomendations would be greatly apprecieated Share this post Link to post Share on other sites
vinylmotivations 143 Posted May 5, 2012 When I had my laserpoint, which I find is comparable as far as speed etc. to the MH series, the pressure required was only about 105, and usually didnt have my speed past about 30- or so.... How much blade do you have sticking out??? Share this post Link to post Share on other sites
Double A 6 Posted May 5, 2012 Thanks for the help ill give those settings a try and the blade is just barely as recomended by uscutter. Tested it on some 631 is cutting just the vinyl and barely making a mark on the back wax paper Share this post Link to post Share on other sites
smokeybearfan 87 Posted May 5, 2012 I run 20-30 speed and 100 pressure on my mh-721 that seems to be its sweet spot. Share this post Link to post Share on other sites
Double A 6 Posted May 5, 2012 Smokey are you using that setting on all vinyl of just the 631? Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted May 5, 2012 Do you guys have a suggestion on blades my cutter seems to peel the vinyl up as it cuts using the 631 Is the blade set to the right depth, i get roll up when i adjust the depth too high Share this post Link to post Share on other sites
jhelms 5 Posted May 6, 2012 I use 60 degree blades on everthing small letters and designs do a lot better with 60 degree blades Share this post Link to post Share on other sites
