SeeJaysPlace 476 Posted April 2, 2012 Can you hook up 2 vinyl cutters to one computer " Windows " I found a smoking deal on a plotter on criagslist and i'm thinking about snagging it up so i have a spare! it is the exact same cutter i have right now MH 721 Share this post Link to post Share on other sites
Neuromax 97 Posted April 2, 2012 It shouldn't be a problem, its just like hooking up two different printers, just be sure to give them different names when you set it up for the first time. I had a my Graphtec and Copam on the same computer at one time. Share this post Link to post Share on other sites
SeeJaysPlace 476 Posted April 2, 2012 It shouldn't be a problem, its just like hooking up two different printers, just be sure to give them different names when you set it up for the first time. I had a my Graphtec and Copam on the same computer at one time. that will work with signcut ? Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted April 2, 2012 It should just when you go to cut it may ask which cutter to use. Share this post Link to post Share on other sites
SeeJaysPlace 476 Posted April 2, 2012 Thanks.. $100 plotter on criagslist i can't beat it really for a backup.. since i only have one cutter right now.. the motherboard and powersupply is worth 100 if my other one goes bad lol Share this post Link to post Share on other sites
BannerJohn 1,324 Posted April 2, 2012 IF it is the exact same cutter you already have..you wont need 2 different setups.,unless you plan on running them both at the same time. Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted April 3, 2012 I have two cutters my dgi om60 and my pcut on one computer working on signblazer works fine just have to change ports for each device Dan Share this post Link to post Share on other sites
SeeJaysPlace 476 Posted April 3, 2012 I have two cutters my dgi om60 and my pcut on one computer working on signblazer works fine just have to change ports for each device Dan ya i have both on the same pc right now and i just have to change the port i like that i have a backup cutter now Share this post Link to post Share on other sites
