hwangstar 0 Posted September 3, 2011 I just purchased the 24' zencut black series and I can't install the driver for it I have 64 bit drive windows 7. ASUS K72J ALSO I can't follow these instructions step by step. Theyre false \\\\\\\\2.1.2 Step 1: Connection Cutter control via USB Install cutter USB drivers, which were delivered by GCC. Please use the instructions given by cutter manual. Cutter control via COM port (serial) Make sure, that cutter and serial Windows port are configured identically. You´ll find this port configuration in the system Control Panel under: System/Hardware/Device Manager/Ports/Communications Port. Select via double click the respective port (e. g. COM1) and activate Port Settings. Default settings are: Bits per second: 9600 or 19200, Data bits: 8, Parity: None, Stop bits: 1, Flow control: Hardware\\\\\\\ Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 3, 2011 have you tried any of the drivers from here? Support page. http://support.uscutter.com/index.php?/Knowledgebase/List/Index/32/zencut-black-driversmanuals Share this post Link to post Share on other sites
hwangstar 0 Posted September 3, 2011 have you tried any of the drivers from here? Support page. http://support.uscutter.com/index.php?/Knowledgebase/List/Index/32/zencut-black-driversmanuals Yes I have tried them from there. idk whats going on. I'm using the USB connection and I thought it would automatically install the driver but all i get are errors Share this post Link to post Share on other sites
Nitsuj 5 Posted September 4, 2011 Could this be one of those problems that the keyspan gizmo is supposed to fix? Not trying to sound like a know it all, I know nothing. But I keep reading "buy a keyspan or you'll be sorry". Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 4, 2011 Could this be one of those problems that the keyspan gizmo is supposed to fix? Not trying to sound like a know it all, I know nothing. But I keep reading "buy a keyspan or you'll be sorry". PM sent. Share this post Link to post Share on other sites
Snapper 30 Posted September 4, 2011 ZENcut Black Series READING AS PRINTER That's right just select the Zencut and your default "PRINTER" and you should be good to go. If not you may have to delete the other printers if they cause a conflict. Share this post Link to post Share on other sites
roxanneupnorth 106 Posted September 4, 2011 Are you on a USB connection?.....If so, you may have to "tweak" USB printer support...But it has been a while for me so I can not quite remember how to do it....Also, sometimes you have to turn your printer off so it does not conflict with the pltter.... Share this post Link to post Share on other sites
hwangstar 0 Posted September 9, 2011 I'm using a parallel to USB adapter. I can't install the driver so I thought it would work. But my great cut cant do anything with the plotter Share this post Link to post Share on other sites
jschelske 0 Posted October 18, 2012 wow. i really wish this post had an answer to the problem. same exact thing is happening to me.... Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted October 18, 2012 wow. i really wish this post had an answer to the problem. same exact thing is happening to me.... Contact us cutter support they can help walk you through it . Dan Share this post Link to post Share on other sites
