Dr12volt1338 116 Posted April 19, 2011 I am having some trouble with this. I am trying to eliminate the lines and cuts or part of the graphic that is "behind" the softball on here... When I open the file in Adobe Illustrator it is exactly how I want it to look when I cut it but when I cut it all the lines from behind the ball also cut. When I try to delete the nodes in Inkscape it is altering the whole bat. What I am trying to get is for it to cut just how it looks. I am not asking anyone to do this for me but maybe some quick steps in the right direction. Maybe node editing isn't the way I want to go. I appreciate any help at all Thank You! softball flames.eps Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 19, 2011 there is nothing to look at, no way to help you that way. Share this post Link to post Share on other sites
Rodger 527 Posted April 19, 2011 In SignBlazer , I do what I think you want to do by using " Split " under " Arrange " on the tool bar . I then use " combine " to put it back together . Share this post Link to post Share on other sites
