lonestarcountrymusic 3 Posted March 19, 2010 Is there a way to edit an image in SB? I havent been able to find it. Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted March 19, 2010 if you are referring to eding the nodes? at the top of the screen next to polyline, NODE EDIT, otherwise you should be more specific on how you want to edit the image Share this post Link to post Share on other sites
cutme 5 Posted March 19, 2010 first we must determine what type of image you want to edit and how. bb Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted March 19, 2010 need to fill in a few things that dont cut right. its for a trailer decal. Share this post Link to post Share on other sites
pyrophire 0 Posted March 20, 2010 need to fill in a few things that dont cut right. its for a trailer decal. you need to specify exactly what you need to edit, maybe show an example of the image or something... Share this post Link to post Share on other sites
cutme 5 Posted March 20, 2010 you should probably read through the learning guide. bb Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted March 28, 2010 well i have looked through some things and i cannot figure it out. basically what im trying to do is get rid of the EST 2009 from the bottom of the image and unfortunately some how the image i had created to that point no longer exist. The only place it does exist is in SB. so if i can fill in or use a brush in SB to get rid of it then i would be set. Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted March 28, 2010 select- ungroup all, select the Est 2009 and delete Share this post Link to post Share on other sites
Truckntran 0 Posted March 28, 2010 You can't select and delete the area? Oops Dakota beat me to it... Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted March 28, 2010 seeing as the image was imported, i cannot select and delete. the image originally impoerted has disappeared and i am only left with the file from SB save. Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted March 28, 2010 nevermind it got the node editing to finally work. Anyone else have problems with SB? it seems to lock up quite often and stop responding quite often. Share this post Link to post Share on other sites
mars 45 Posted March 28, 2010 I have just started back using SBE and find it very stable - I am running it on a windows 2000 and also on windows xp machine. The more I use it the more I find to like about it. Runs great for me and does a beautiful job cutting on my Copam CP2500. I haven't gone through the learning guide, but do plan to - -mike Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted March 28, 2010 im running it on a windows 7 machine and it seems to have problems where it stops responding and SB has to be shutdown and restarted. Share this post Link to post Share on other sites
mars 45 Posted March 28, 2010 Did a search and found this topic - http://forum.uscutter.com/index.php/topic,24869.0.html seems like they are running with windows 7 - might post a comment in this topic and get some help from people who are using win7. Hope you get it figured out. Sorry I can't help on win7 -mike Share this post Link to post Share on other sites
