Dakotagrafx
Super Moderators
  • Content Count
    21,365
  • Joined
  • Last visited
  • Days Won
    641
Everything posted by Dakotagrafx
  1. Dakotagrafx
    How to check used Graphtec
    run with it - should be ok - but like others have said we are not there to test it
  2. Dakotagrafx
    Should be a good solid unit unless he left it in an unseated shed for 2 Minnesota winters. In that case I would check everywhere for signs of rust. They are a precision device and should be handled as such. I am also a hard core graphtec user for many years
  3. Dakotagrafx
    Sublimation on a tumbler with black ink
    use cactus wraps in stead of a mug press - the bottom and handles wick away the heat but in an oven the entire mug is heated evenly. part 2 is buy quality mugs - not the cheapest you can find as the coating has to be applied evenly for the product to come out evenly
  4. Dakotagrafx
    CE 7000 Oddities
    on the adding material to the end - my guess is that you are not allowing enough material there when cutting your paper and the plotter needs enough past the end to find the marks - without enough the sensor that senses paper length will stop the feed before it gets to the marks - you can either add to the length or you can turn the sensors off
  5. no help on this problem - but if you sign up on the forum (no spam no cost) you don't have to wait for a mod to approve you post - part of our controlling spam efforts
  6. Dakotagrafx
    Any inputs please!!??
    my opinion has never been worth more than the 2 cents
  7. Dakotagrafx
    Roland BN-20A
    I have had 3 solvent printers and even with then doing daily maintenance themselves if left to sit without printing you will get clogged heads that don’t clear up if not used regularly. That is why I sold my last sp300i. We started going on vacations of 3 weeks or more and every time I would have to replace the black head at $700. I think the head on the bun is closer to $2000 so make sure you can keep it printing and willing to Rick board damage replacing the head yourself. If you can keep it working every couple of days to a week the. They work great for transfers. For me without the volume now I find it better for just farm it out
  8. Dakotagrafx
    Personally I would tape it to make sure there is no stretching and protect it when applied. A 7 year cast is pretty thin and easily stretched . Just my 2 cents
  9. Dakotagrafx
    Can Someone Vectorize this for me?
    even though altered - Harley Davidson protects their "shield" as part of their property pretty aggressively -
  10. Dakotagrafx
    Anyone using the new Sawgrass sg500 or 1000?
    With the Ricoh sawgrass printer and ink, use Tex print-r it is made for the fast moving Ricoh with gel I got and won’t smear like other paper. Hope this helps. Even when printing onto specialty decal material the Tex print r is the right choice to get to that point. As far as using the decal paper , I have only seen one person years ago doing that as the cost is so high per decal compared to a solvent printer
  11. For the short time I had a ce7000 it ran on the drivers from my ce6000 it replaced
  12. Dakotagrafx
    windows 11 now on design computer
    cutter computer not changing, nor the other 2 but first impression on design computer is I like it. Pretty sure the Mac crowd will see some similarities. I customized some widgets, tested my graphtec pro studio, Corel, etc and everything seems happy so far. Keep in mind this is a machine with 8 core and ryzen7x , 64gb ram so it isn’t a stripped down model test.
  13. no time to play as I have to get up early for 2 hr drive to dr. anyone else in the guinea pig status?
  14. Dakotagrafx
    What's this font????
    I would use Just In The Firestorm (Regular) - convert to outline - put a rectangle thru where the cut out is and punch it out - bada boom bada bing - close enough
  15. Dakotagrafx
    Encad Novacut 24
    wow - there is a blast from the past - about 10+ years ago I messed with a couple - can't remember which drivers back then but with you luck - they wasn't worth putting anyting into back then but I understand people that want to tinker
  16. Dakotagrafx
    Using SG-300 to cut Vinyl Transfer Stickers
    By all means then, do what you do and let them worry about taking care of their equipment
  17. Dakotagrafx
    it will cut regular vinyl fine - but I never used my roland printers for cutting other than contour cutting because my thinking was why put that wear and tear on the expensive machine - I always kept a graphtec for my vinyl cutting part of the business - until I sold the printers
  18. Dakotagrafx
    working in the background
    working in the background to fight spammers and not answering questions as much for a couple more months these photos pretty well explains the reason to all the regulars you are doing a spectacular job helping everyone as usual
  19. Dakotagrafx
    lotta work for a small bathroom, but don't plan on doing it again. guess I am getting to be an old bugger
  20. Dakotagrafx
    application tape trick worked great - entering the home stretch we hope - changed out mind on the main bathroom flooring and waiting on new stuff to come in. whodathought application tape, and cutting 631 for layouts would be a part of a bathroom reno
  21. Dakotagrafx
    Sure Cuts Alot 3/MH871
    Make sure you also install the usb chipset driver on the new computer so the plotter can communicate with whatever cutting software you use
  22. Most of the older plotters work with the Roland pnc-1000 drivers.
  23. Dakotagrafx
    Newbie here
    if you keep them printing like arty does that isn't a bad choice but when you leave on a transatlantic or transpacific cruise, just plan on a new printer when you get back lol
  24. Dakotagrafx
    Newbie here
    epson is cheapest to get into it but sawgrass virtuoso uses ricoh and gel inks - much more forgiving if you are printing every few days - I have gone 3 months without printing on a ricoh and was no problem - epson's not so forgiving - it is a lot of fun -
