Guest Dnice Posted March 27, 2020 Can some please help me. I new to using my software and I'm trying to get my text to be 4(h) x 11(w) on my cutter. When I keep trying to put it in the program it's changing my size. Can someone please assist me with this. Thanks in advance. Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted March 27, 2020 Dnice If you sign up to the forum you will receive faster responses since all guest posts have to be approved by moderators 1 Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 27, 2020 What is changing? , Be more specific. Is the cutter not cutting the size you are sending to it from Vinyl Master? If so. calibrate your cutter. That is located in the software. If that is not it, then provide more info. 1 Quote Share this post Link to post Share on other sites
skarekrow 1,842 Posted March 27, 2020 After creating your Text with the Text Tool, Select the Object Pointer (A). Click the Lock (C) to unlock the Proportional Ratio and either insert your Size requirements in the Height / Width boxes (B) or Grab & Drag the Text Object itself. Setting these 2 Sizes should yield the correct Size at your Cutter providing it is set up Properly. The Read-outs in the D boxes are for the Typographical size of the Font set by the Typographer, and the Physical Size, the actual size of the Flush Capitals (T, H, L, etc). Here's a Video that covers most of these Basics.... They have a large collection that includes other Useful Text Videos HERE. 3 Quote Share this post Link to post Share on other sites
darcshadow 1,627 Posted March 30, 2020 The two different size things for Fonts can be a bit confusing. Typically I don't even pay attention to them, just type out what I want, lock the aspect ratio and resize as necessary. 1 Quote Share this post Link to post Share on other sites
Wilson 43 Posted March 30, 2020 The two different text sizes (D in Skarekrow's picture) can make a big difference. One is the max height of all text in your text box and the other is your font size. Where I've found the font size useful is if you're trying to create names or other text of the same size... say Bella and Chippy. If you just set the text size (not the font size) to 1 inch, on Bella it's measured from the bottom of the B to the top of B and on Chippy it's measured from the bottom of the p to the top of the C. Your letters in Chippy are then smaller than in Bella. If you keep the font size the same then you don't have this problem. 1 Quote Share this post Link to post Share on other sites
darcshadow 1,627 Posted March 30, 2020 My work around in that situation, get one the size I want, then copy and paste it and change what it says. To each his own, there's always a dozen or more ways to skin a cat. 1 Quote Share this post Link to post Share on other sites
