express2100 154 Posted April 2, 2014 Both of my media rollers are bent on my new 6000-60. Not severely but enough to cause the media roll to sort of stall and then quickly move forward as it meets and rolls past the bent area. I noticed this the first time I used the machine after the rep set it up. Anyone else see this issue? I'm pretty sure this could cause problems and unnecessary wear on the machine down the road. The rollers are just light gauge tubing so do I.... 1) remove and straighten them myself? 2) leave them alone as it is a normal characteristic? (doubtful) 3) call the rep and warranty new rollers? Share this post Link to post Share on other sites
outlaws 102 Posted April 2, 2014 If It was me...I would do number 3. Since it is a new machine I wouldn't want to work on it and void my warranty. Butch Share this post Link to post Share on other sites
Coaster36 327 Posted April 2, 2014 Mine are bent as well. Your not supposed to let the machine pull the material off the rollers. Your supposed to unroll enough material for the job before you start cutting. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 2, 2014 new machine I would probably call if a small tweak didn't straighten them - not sure on that machine but the ce-5000 uses a thin walled stainless tubing Share this post Link to post Share on other sites
jaybyrd 3,770 Posted April 2, 2014 Heard of bent rollers on several ce-5000's and never heard of it causing a problem. Share this post Link to post Share on other sites
MrMopar64 47 Posted April 2, 2014 There have been a few posts on here about that... mine also had bent rollers The problem is they don't stay straight even after being fixed the material is just to thin They have not caused any problems so far MM64 Share this post Link to post Share on other sites
Go-C Graphics 856 Posted April 2, 2014 My new Graphtec did the same thing right out of the box. It shouldn't cause a problem because your machine shouldn't be pulling it from the roll. Share this post Link to post Share on other sites
express2100 154 Posted April 2, 2014 AHH YES....I will make sure I pull enough off of the roll for the job....Thx So in other words new replacements could be bent when they arrive or shortly there after. Might as well try to straighten these for now and look for some solid stock to replace them with. I know it's not the most expensive plotter around but it is a lot of money to me and I guess I just like things to run straight and true. If the media rollers can not support the MEDIA then they are worthless and should be improved. My OCD hates things like this....Damn value engineering! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 2, 2014 Maybe your next upgrade could be to a FC model, much larger, sturdier, media rollers... The whole machine is sturdier. and bigger. 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 2, 2014 Last stand I bought I actually ordered heavier rollers . . . They still bend easy. Share this post Link to post Share on other sites
MrMopar64 47 Posted April 2, 2014 AHH YES....I will make sure I pull enough off of the roll for the job....Thx So in other words new replacements could be bent when they arrive or shortly there after. Might as well try to straighten these for now and look for some solid stock to replace them with. I know it's not the most expensive plotter around but it is a lot of money to me and I guess I just like things to run straight and true. If the media rollers can not support the MEDIA then they are worthless and should be improved. My OCD hates things like this....Damn value engineering! Solid stock will bend eaiser then tubing... heavier wall tubing would be better or another small tube that just fits inside that one MM64 1 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 2, 2014 Maybe the CE5000 -60 I got for my son was better, cause his rollers are fine,, and he has been using it for 2 years . He uses 50 yd rolls on them, no problems. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 3, 2014 Maybe the CE5000 -60 I got for my son was better, cause his rollers are fine,, and he has been using it for 2 years . He uses 50 yd rolls on them, no problems. his were packaged well but if he dropped a new 50yrd sideways they would bend a little - not bad but it happens - I am sure the fc is stronger. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 3, 2014 his were packaged well but if he dropped a new 50yrd sideways they would bend a little - not bad but it happens - I am sure the fc is stronger. rollers are much bigger, I just measured the roller on the FC, it has a circumference of about 4/3/4" round. 1 Share this post Link to post Share on other sites
Coaster36 327 Posted April 3, 2014 Im pretty sure mine were like that when I opened the box. They wouldnt ship something like that. It would never pass QA. Call customer service, I bet theyll say its ops normal. Share this post Link to post Share on other sites
