fenceman 0 Posted December 8, 2011 my setup -windows xp home - signblazer elements version 6.0.21 - uscutter lazerpoint I have no usb driver disk. the cutter is linked to comp. with a usb cable the comp. has no internet connection. the cutter and sbe has worked on a different computer before. i have the cutter manual i need a way to download? the usb driver to one computer, burn it to a cd then download it to the computer with the cutter. i found a link on the uscutter website that might be what im looking for; but the link will not open in my browser. im not very computer savy and have never fooled with cutting before. ill be watching this topic close im needing to have the machine up and running today 12-8-11 any information is much appreciated thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 8, 2011 start here http://start.uscutter.com/ Share this post Link to post Share on other sites
fenceman 0 Posted December 8, 2011 thanks so much. im about to burn it to a disk and try it..... ill let you know as soon as i find out if it works. thanks again Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 8, 2011 your welcome, good luck with your ventures..here is also a great newbie manual, written by a forum member, to help out. download in first post http://forum.uscutte...your-first-cut/ Share this post Link to post Share on other sites
fenceman 0 Posted December 8, 2011 Thanks I was able to get it on the disk and on to the computer... I double clicked the icon and a black box popes up with some white lettered computer jargan( I guess that's what it was) at the end of the text there was a counter for the install but when it finished it just closed out instead of putting me through the wizard setup like the manual illustrates.... What do I do from here? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 8, 2011 why can't you connect the other computer to the internet If it's there with you..? Just long enough to do your setup.. Or take it to a friends with internet, and download what you need. Share this post Link to post Share on other sites
fenceman 0 Posted December 8, 2011 well i was trying to avoid this but i went back to the shop and grabbed the comp. and the cuter and im going to hook it up here at the house and see if that link will work with it hooked up and everything.. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 8, 2011 that sounds like a better plan... hope it works out for you... Share this post Link to post Share on other sites
fenceman 0 Posted December 9, 2011 Well I got it working that Internet connection made all the difference, that and the output being the correct choice Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 9, 2011 great, good luck... Share this post Link to post Share on other sites
