Jburns
Members-
Days Won
9
Everything posted by Jburns
I have the same cutter - but haven't tried thru signblazer- when using signblazer, do you have the Summa cutting software open?
that is killer!! Same one I have - I bought mine at an estate sale - but not for 10 bucks!
Spanish + English = Spanglish
Blade's Script- ( sharpie)
Man, I just wrapped up some MX decals for a family members company. I bought some 6 mil vinyl along with 12 Mil Heavy duty gloss laminate for MX , ssnow mobiles, etc. I had to contour cut - 60 deg. blade- Tangental mode-- almost highest force setting on the GS15 vinyl cutter- took three passes. Total is 18 mil THICK.- a credit card is about 20 mil I think. Turned out very clean for 3 passes Pics:
Thats a good one I am sure Blade pays special attention to detail when cleaning your car, and certainly would not cut any corners!!
Curves are Cutting Very Slowly
Jburns replied to 13ruce's topic in GraphTec Cutting Plotter Discussion
Hello, that is a very nice machine -- and certainly capable- Do you have the user manual? There is probably a function that is slowing it down. Or double check the file after import- perhaps more nodes were added? -
Also try holding your pointer over the icon- and see if the other shapes flag put on the tools bar to the right
Ok, noob question, can't get two images to appear together .
Jburns replied to stewiegriffin's topic in Flexi
My guess is that the two images are different colors ex. Two different shades. Try selecting all images and then assigning a single color- then plotting. -
My favorite has been R-tape 4075- been "Ole reliable" for years.
Hi all, There is a large auction on Thursday here in Colorado. ( I am not affiliated with). a large company that did/does personalization gifts. currentcatalog.com I am headed down to look at the items in this auction today for myself. - embroidery, heat presses, engravers, lasers, and printing equipment. I will be bidding on some items. Let me know if you would like me to inspect an item for you. note- fees are kinda high- about 21%. I will be there about 12 MST. - message me in the next 2 hours if interested. https://www.bidspotter.com/en-us/auction-catalogues/timed/capital-recovery-group/catalogue-id-cap10120
Here is what I bought: - I will be selling two of the DK8 heat presses with attachments: 1. Signature Engraver 8080S, computer and software. 2. Qty 3 DK8 Heat Presses ( two to sell). 3. Vision engraver CNC router ( to resell possibly). 4. auto Box bander - (to resell) 5. Label rewinders ( for my gerber edge prints)
This place apparently is one of the largest mail order and gift companies in the US. they bought out another company in Virginia- and brought their stuff to Colorado. I had a chance to loot at the Epilog's -One had its main board pulled out the other with a bid on it had belt removed from carriage assembly. So I wouldn't recommend bidding.
This place is so big
Yeah - out of habit I did draw single lines, and right click - end on the second point- but you can just continue- that would be easy also. Thanks for the tip above on CTRL key.
Man, I have added hundreds of weed lines in my old sign blazer files: 1. Select polyline, and draw perpendicular or horizontal lines. 2. Overlap them a little at intersections. 3. Make sure the color is the same as rest of design
I haven't heard of that film before - but looked it up and it seems impressive. At 1 mil it should be able to cut with a decent plotter. Does it have a backing paper on the film, or come straight off the roll as transparent?
Do you have the designs done in vector format? I have some left over motorcycle grade vinyl and heavy laminate I will do a free (SMALL) sample for you. ( Convex 6mil and 2.5 or 12mil lam) (I am doing some personal training jobs on my Omega 6 software and printer.) shoot me a pm if interested.
That is a standard thickness- 2.5 mil. did the design have intricate cuts and thin strips?
thanks Goose-- yeah tracking is perfect straight- I have the older summa and an envision, but with something so thick, I could not imagine how a swivel blade would handle it.
Blade- it actually may be a 45.
Please tell me if there is a cure for this? Anything I can do right now?
Jburns replied to T-Shirt Lady's topic in SC Series Vinyl Cutter Discussions
Looks like your COM port is recognizing your cable in both Sure Cuts and SB... I assume you have the driver for the cable installed on your computer since it worked with the MH cuttter. Open device manager, and check that ports communication parameters- BAUD rate. - and see if it matches the Baud rate of the cutter. Also check COM settings in SB. Write down settings if you make changes, if you need to revert back.
