aamotox 0 Posted May 9, 2007 MH721 Artcut LPT1 I have asked these questions before but no one has come up with answers yet. My machine will stop very abruptly in the middle of cutting, usually accompanied by some noise. When it starts cutting again, the rest of the graphic is shifted. For instance, if it cut the outside of an O and then went back to cut the inside, they would be off or not cocentric. The text on that same line also is shifted. This must be a hardware issue that I would like to get fixed. I also have a problem that I've heard others complaining about. That is the machine quitting in the middle of a job and cutting a line, sometimes to the left till it hits the stop and sometimes right up the vinyl, either ruining the job or wasting lots of vinyl. Please help before I throw this thing in the trash. Share this post Link to post Share on other sites
TaterNuts 3 Posted May 9, 2007 I have a diffrent brand machine that did that with the LPT connection, however it didnt shift the graphic on the vinyl... Try the serial connection, works great now Share this post Link to post Share on other sites
aamotox 0 Posted May 9, 2007 When it stops abruptly it must slip or something cause it makes a bad noise and then is out of alignment. I'll try the serial port though, thanks. Are these problems something I'm gonna have to live with? Have you had problems with your machine. I know these cutters are inexpensive but.... Someone asked me where I got my cutter but I'm afraid to say, because of the problems I've been having I don't want to recommend them. In fact I'm considering switching to something else. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted May 9, 2007 sometimes,when I have a full or mostly full roll of vinyl,it will jerk...make a loud noise,and the cut will be out of line,when it gets tight....So I roll enough off to do the cut,usually,unless I forget.Just a suggestion. Might work. Or not.BUt,worth a try. Just my 2p worth. Share this post Link to post Share on other sites
Daniel T 0 Posted May 10, 2007 hbere comes 2 more cents worth......... is your machine properly grounded? static electricity can be a bugger. good luck. Share this post Link to post Share on other sites
kenimes 42 Posted May 10, 2007 I would also suggest upgrading to SignCut. Seems to be a better cutting program with support. ArtCut has not responded to our emails for help when cusotmers have an issue. It may also be a hardware issue, but before we start replacing parts, we should try a better program. Share this post Link to post Share on other sites
mudstock 0 Posted May 10, 2007 You can try the signgo product. It is a 30 day trial but you can at least see if it is software or hardware related. Signcut is also an option but signgo works immediately right after selection of cutter. Not much config to do . see if it works http://www.signgo.com I was running in 2 minutes and works flawlessly. not saying you should buy it. But it will be a quick troubleshoot. Share this post Link to post Share on other sites
UpNorthPromo 3 Posted May 10, 2007 Mine does that all the time and everything goes out of alignment. It seems to happen when the 1mb of memory is used up. then it reloads another megabyte and does it again. I have wasted many yards of vinyl because of this. Share this post Link to post Share on other sites
TonyTomahawk 0 Posted May 12, 2007 I am having the same problems with a diagonal line. I am setting up my files using Illustrator CS2 and back saving to version 3 in both .eps and .ai files. (I have also tried with different versions of Illustrator) I am using Sign Cut and have downloaded the most recent version along with the latest drivers from US Cutter. The machine is grounded and I am using the serial connection. I have seen many posts with this problem, but no solutions. Share this post Link to post Share on other sites
Guest fivestar Posted May 12, 2007 Tony post a file that you are having problems with, it sounds to me like there is too many nodes and causing a buffer problem. I've had this problem before and by reducing the amount of nodes it rectified my problem. Share this post Link to post Share on other sites
TonyTomahawk 0 Posted May 14, 2007 This is one of the files that it has happened recently. What are the nodes you mentioned? Banner.ai Banner.ai Share this post Link to post Share on other sites
Guest fivestar Posted May 14, 2007 Well that definitely isn't the problem as there are only 128 nodes. I'm not at my machine now, but I would have to say that it's the size (177 inches) (buffer underrun) that is giving you the problem. Though I have cut bigger sizes then this with no problems. That would be the only thing I can thing of that would cause your problem, now that the nodes are so small. Share this post Link to post Share on other sites
TonyTomahawk 0 Posted May 15, 2007 Do you have any suggestions on how to correct the problem? Share this post Link to post Share on other sites
kenimes 42 Posted May 15, 2007 It cut out fine for me at a smaller size. What size are you trying to cut, the 177 inches in width? Share this post Link to post Share on other sites
TonyTomahawk 0 Posted May 15, 2007 We are cutting the 177" width. It was for a large banner. Share this post Link to post Share on other sites
kenimes 42 Posted May 15, 2007 OK- I'll try that size today. Share this post Link to post Share on other sites
TonyTomahawk 0 Posted May 18, 2007 I think the random cut lines is an issue with Sign Cut. I downloaded a demo of WinPCSign and cut the graphics I was having an issue with and they cut out fine. Share this post Link to post Share on other sites
