jmoney 0 Posted July 28, 2008 How do I set it where SBE is what opens the graphics I want to look at my computer is set to open withe some version of microsoft imaging and it is no longer available any help is greatly apreciated Share this post Link to post Share on other sites
kenimes 42 Posted July 28, 2008 I think you can right click on the file, and select the Open With. Share this post Link to post Share on other sites
lori 0 Posted July 28, 2008 Right click on the file and go to properties. In the general tab there is a spot that says open with then will tell you what program it opens up in. To the right there is a tab that says change. If you click on that it will let you pick the program to open it with and you don't have to choose it every time it will automatically open with that program. Share this post Link to post Share on other sites
duke 12 Posted July 29, 2008 hi lori, i did this and signblazer programme is not there. i guess because i cannot register it and am only allowed to use trial version this is very annoying. any ideas how to get pics etc; into signblazer from corel drawx4? rgards duke Share this post Link to post Share on other sites
Jay2703 704 Posted July 29, 2008 If the program you want to open the file type with is not in the list then click Browse. If you installed it in the default location it should be here: C:Program FilesCutting TechnologiesSignBlazer Elementssbnt.exe Share this post Link to post Share on other sites
duke 12 Posted August 7, 2008 hi all, i can't export either. s/b is not installed as i am still waiting to register. i can only use trial mode. regards duke Share this post Link to post Share on other sites
Jay2703 704 Posted August 7, 2008 hi all, i can't export either. s/b is not installed as i am still waiting to register. i can only use trial mode. regards duke You can still export in trial mode. Share this post Link to post Share on other sites
duke 12 Posted August 8, 2008 hi jay, when i right click and go to roperties etc; s/b does not show up in there. i think it is cos i can only use trial mode because i can't register and the programme is not downloaded to computer. regards duke Share this post Link to post Share on other sites
Jay2703 704 Posted August 8, 2008 If the program you want to open the file type with is not in the list then click Browse. If you installed it in the default location it should be here: C:Program FilesCutting TechnologiesSignBlazer Elementssbnt.exe Click on Browse from the properties panel and you can navigate to this path. Share this post Link to post Share on other sites
duke 12 Posted August 10, 2008 If the program you want to open the file type with is not in the list then click Browse. If you installed it in the default location it should be here: C:Program FilesCutting TechnologiesSignBlazer Elementssbnt.exe Click on Browse from the properties panel and you can navigate to this path. i tried that, still not there. regards duke Share this post Link to post Share on other sites
Knobhill 0 Posted August 18, 2008 How do I set it where SBE is what opens the graphics I want to look at my computer is set to open withe some version of microsoft imaging and it is no longer available any help is greatly apreciated Try importing the files. If they're not native to SBE you'll not be able to view them directly. Share this post Link to post Share on other sites
Rodger 527 Posted August 18, 2008 hi jay, when i right click and go to roperties etc; s/b does not show up in there. i think it is cos i can only use trial mode because i can't register and the programme is not downloaded to computer. regards duke Hi , Being installed & being registered is 2 different things . I have SBE installed on both computers ( 2 installs on 1 computer , downloaded from different sources ) & use SBE in trial mode . It does everything in trial that it does after it's registered except open without clicking 4 times . You have SBE installed , but just like me , are not up to speed on all the controls ( Jerry , the maker of SB , said almost nobody knew all the tricks to SB Read thru the SB section & most of the general questions have been answered ... ESPECIALLY the registration issues regards , Rodger Share this post Link to post Share on other sites
phrog 0 Posted August 18, 2008 If it were me I'd open graphic files (jpg, bmp ) in a windows program such as paint.exe (you'll find it under programs/accessories SignBlazer won't "open" these type files. You can "Import" them into SB then look at them, but opening them in paint.exe would be easier. Also if you have photoshop, paintpro, or any image program you can use that. Personally I have photoshop cs and use that to view all my images. Share this post Link to post Share on other sites
