mcdesign 0 Posted July 1, 2008 it seems the cutter is not level with the base.. is there a way to adjust this? or has any one run into this same problem Share this post Link to post Share on other sites
haumana 1,221 Posted July 2, 2008 "base" as in the stand? If the stand was put together properly, then everything should be square and level. If you talking saying the cutting "window" (I don't know the correct terminology) is skewed one way or another, then contact Ken Imes and he'll work on this issue you with you. BTW - to the forum! Share this post Link to post Share on other sites
kenimes 42 Posted July 2, 2008 Could be the cutting strip not seated on one end, or you have the blade sticking out way too far from the blade holder. If you can see the full angle of the blade sticking out from the blade holder, it is out too far. Share this post Link to post Share on other sites
Popeye 0 Posted July 3, 2008 Follow this to make adjustments Blade Adjustment-rev-01.pdf Blade Adjustment-rev-01.pdf Share this post Link to post Share on other sites
