haumana 1,232 Posted February 25, 2024 Anyone else out there that runs a Graphtec CE6000-60 Plus & Graphtec Studio setup? I recently did a quick text cut, and noticed that the cut text was smaller then what I had laid out in the workspace. I thought that this was kind of odd, and was concerned that the overall scale was off, but when I checked all the setting, it's all set 100%. I then cut a 3" square, and it was spot on, so I'm wondering if this is just the text that's doing this, and if it is, has anyone else ran into this situation - and if there's a fix. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted February 26, 2024 Anyone else out there that runs a Graphtec CE6000-60 Plus & Graphtec Studio setup? I recently did a quick text cut, and noticed that the cut text was smaller then what I had laid out in the workspace. I thought that this was kind of odd, and was concerned that the overall scale was off, but when I checked all the setting, it's all set 100%. I then cut a 3" square, and it was spot on, so I'm wondering if this is just the text that's doing this, and if it is, has anyone else ran into this situation - and if there's a fix. I don't run the cutter or program. Does that cut from live text or do you have to convert the text to lines and curves first? Share this post Link to post Share on other sites
haumana 1,232 Posted February 26, 2024 I don't run the cutter or program. Does that cut from live text or do you have to convert the text to lines and curves first? Live text. It was just a basic sans-serif font, Helvetica. Share this post Link to post Share on other sites
darcshadow 1,643 Posted February 26, 2024 How are you setting the font size? There is a setting for font height, but that doesn't mean the true height will be what you set. I forget exactly how it works, but it's a little weird. Check the measurement of the text after you type it out and see if the size is what you expect. Share this post Link to post Share on other sites
haumana 1,232 Posted February 26, 2024 I was setting the font height by using the pull handles to get them to be 5/8" (0.625) high (in Graphtec Studio). I ended up with something just under a 1/2" Share this post Link to post Share on other sites
darcshadow 1,643 Posted February 27, 2024 Finally got around to playing with the software. When you type out the text., the box that appears around the text is not the size of the test. It extends above and below. I'm assuming below for lower case letters and above for super script or some sort of punctuation maybe. As far as I know, the only way to get the true size is to convert the text to curves then resize it. Share this post Link to post Share on other sites
haumana 1,232 Posted February 28, 2024 Finally got around to playing with the software. When you type out the text., the box that appears around the text is not the size of the test. It extends above and below. I'm assuming below for lower case letters and above for super script or some sort of punctuation maybe. As far as I know, the only way to get the true size is to convert the text to curves then resize it. Got it. Thanks! not sure why it needs to be that hard. I typed out all caps, and thought it would the right size. Maybe I should be considering SCALP Share this post Link to post Share on other sites
darcshadow 1,643 Posted February 28, 2024 I've not been impressed with the Studio program for design. I use Inkscape for design and just use Studio for cutting. Share this post Link to post Share on other sites
haumana 1,232 Posted February 28, 2024 I'm not impressed with the program either, but I use it in a bind or if I'm just cutting simple text. Though now I know that it cannot be trusted to give me accurate test sizes Share this post Link to post Share on other sites
Wildgoose 4,200 Posted February 28, 2024 I'm not impressed with the program either, but I use it in a bind or if I'm just cutting simple text. Though now I know that it cannot be trusted to give me accurate test sizes Try converting the live text after writing it out and at that point it will be an object and you should be able to nail the size. I use SignCut Pro 1 (the old original) and I have to convert all my text anyway. That's why I asked the question. If the 3" object was spot on it pretty well has to be something to do with the interpretation of the text. If working on something that will need revised later I save a working file with some live text saved over on the side so I can recreate the overall thing if needing to modify. Then I save a cut file with the text all converted. Share this post Link to post Share on other sites
haumana 1,232 Posted February 28, 2024 Try converting the live text after writing it out and at that point it will be an object and you should be able to nail the size. I use SignCut Pro 1 (the old original) and I have to convert all my text anyway. That's why I asked the question. If the 3" object was spot on it pretty well has to be something to do with the interpretation of the text. If working on something that will need revised later I save a working file with some live text saved over on the side so I can recreate the overall thing if needing to modify. Then I save a cut file with the text all converted. Excellent advice. Mahalo! 1 Share this post Link to post Share on other sites
