Design1 0 Posted October 3, 2023 Hello Experts, I don't remember when I was here last but please help :) I have a Graphtec CE3000-60 for a while and I used it many times. We had moved and I packed as if it came from factory. As I load the media and it checks the width, it starts to cut some text. I tried all I know with no good results. I tried resetting to factory default by holding the up arrow and on switch and shows this: "NOVRAM INT." I let go the on switch and it shows this: HL metric ENG. Can someone help? Thank you Share this post Link to post Share on other sites
darcshadow 1,626 Posted October 3, 2023 The text that it cuts, is it always the same? Have you let it finish the cut and then read the text, what does it say? Is the cutter connected to the computer when this happens? If so, try disconnecting it from the computer and see if it still does it. Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 3, 2023 Many years back (2014) there was a thread about this "NOVRAM INIT" issue, apparently it has something to do with a capacitor within the electronic circuitry. (motherboard) We don't know how exactly the problem got resolved, but the post above makes a suggestion to clear the failure. Share this post Link to post Share on other sites
