Guest Edward Morales Posted January 12, 2023 I’ve been working on a project ready for cut, and after I separated my image to cut by color. My program froze. When I reopened most of my progress was gone but when I opened recent file it showed up on the thumb nail when I closed out file it ask to save and I hit yes and when I open the recent file it open the file I had just closed. Can I revert before the save because I never saved the original before the freeze. Quote Share this post Link to post Share on other sites
darcshadow 1,627 Posted January 12, 2023 Unless you have a backup someplace I believe you're out of luck. Quote Share this post Link to post Share on other sites
kainth.c.s 53 Posted January 12, 2023 I’ve been working on a project ready for cut, and after I separated my image to cut by color. My program froze. When I reopened most of my progress was gone but when I opened recent file it showed up on the thumb nail when I closed out file it ask to save and I hit yes and when I open the recent file it open the file I had just closed. Can I revert before the save because I never saved the original before the freeze. Look online for some backup files being created for your particular programing software. Almost every software does it by default. It is just the matter of finding it out which file. Hopefully, your software might have some backup file saved somewhere in the temporary files folder. If you happen to find one, just google it on how to retrieve it. Many a times the backup files are retrieved by the same software. Fingers crossed by if it fails, then really tough luck mate Quote Share this post Link to post Share on other sites
haumana 1,220 Posted January 18, 2023 Sorry to hear that you lost a lot of your work. VM has a very basic ability to configure automatic backups, but maybe this will help. At any rate, if you keep your artwork and working graphic files on a single computer, I would suggest either subscribing to an online backup service such as BackBlaze or Carbonite, and/or get yourself an external drive to manually backup your files periodically. When I get desperate, I will have Explorer search the entire computer for anything with a particular file extentsion (ie. *.docx, *.xlsx, etc.). It might take a while, but it might point you in the right direction. Good luck. Where to open a possible backup file in VM: Default location for my VM backup files: File extension for the VM Backups: Quote Share this post Link to post Share on other sites
