JeffScott 0 Posted March 1, 2022 Hey folks, could really use some help. I searched for this topic and used some of that knowledge gained so far. I have a large 6ft x 2ft image I'm cutting and the cutter goes over it twice causing all kind of mayhem. The .bmp was sized in AI and there is only 1 layer with 1 image present. I'm not sure what to check in vinylmaster cut v4.3. I can't see a double image in there. So I've cut this image twice and it's happened both times. I hope it's cool to attach my file, maybe someone could see something with it. It's a lower part of a 2 part distressed American flag. Any help is greatly appreciated. Left Bottom.~vDoc Quote Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted March 2, 2022 why don't you export the image as an .eps and post it.?. Only people with Vinyl Master can look at it. Many people don't use it. I tried to import and open it into a VinylMaster DSR demo. Nothing was there. I have another software, that I can import into, but I need it as an .eps. Quote Share this post Link to post Share on other sites
Camel 7 Posted March 2, 2022 I tried opening it in my VM DSR v5, it's opening as an image and not a vectorized file, it's also a backup of your file, notice the ~ in the file extention. I suspect you have two lines around the outer edge and need to "weld" or "combined" the image even though your eye cant see them. It looks like you wanted a stencil (hence the size of the background was your measurements) however I attached both. Left Bottom-1StripesnoBackground.vDoc Left Bottom-1Stencil.vDoc Quote Share this post Link to post Share on other sites
JeffScott 0 Posted March 2, 2022 Here it is as an .EPS file. Thank you for helping MZ SKEETER! And thank you Camel! Left side bottom.eps Quote Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted March 2, 2022 I cannot do anything with it with the box around it. It cannot be ungrouped. Did you weld it or something? Quote Share this post Link to post Share on other sites
haumana 1,228 Posted March 2, 2022 Is it cutting the entire graphic twice, or just some areas? You have some smaller pieces in the layout that are the same color as the larger, are they meant to be cut outs? I've recolored the smaller pieces that are embedded. If it's only going back to cut the pieces I recolored, then the cutter is doing it's job, because you have those cut line in there. If it's re-cutting the whole job, then it's probably something in the VM settings that you need to take a look at. Which version of VM are you using? If you do not mean to have those recolored area in your graphic, then remove them completely. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted March 2, 2022 I got it, it has a mask over the design, which was the box. I would think those cut outs belong in the design. It is supposed to be a distressed flag. I have seen those. Grouping it should cut all (cut outs also) at the same time. I don't see any other problem. Quote Share this post Link to post Share on other sites
JeffScott 0 Posted March 2, 2022 I grouped the image in AI. The cutouts are meant to be there. Thanks for getting back with me. I'm using Vinylmaster Cut V4.43 Quote Share this post Link to post Share on other sites
GFY Design 0 Posted March 6, 2022 Here are the fixed files. If you run into something like this in the future and can't find the causal factor, I'd convert the item(s) back into a Bitmap and then re-run the Vectorize feature. That would clear any unseen conditions causing the problem. However, this process would be project dependent and could potentially degrade the original vector's quality. Take care, -Russ Left_Bottom.eps Left_Bottom.vDoc Quote Share this post Link to post Share on other sites
GFY Design 0 Posted March 6, 2022 Also, if you haven't checked already, verify that the number of passes is set to 1 in VinylMaster. 'Send to Cutter' > Select 'Cutter Control' Tab > Passes = 1 Quote Share this post Link to post Share on other sites
