JonaDoom 0 Posted February 15, 2022 Hi Guys! I have a question about my graphtec plotter. I have a CE7000-60 which is a couple months old maybe 2-3. I have had no issues so far with it and its been cutting flawlessly. I cut die cut stickers with the perf channel on it and everything comes out amazing. I been having a recent issue though where I print something and laminate it, once I do that I load it on the cutter to read the registration marks. It will start to cut everything good but when the head moves from one side to the other to start a new row it will scratch the top part of the laminate. It’s pretty noticeable when the light shines on the laminate,. I know why it happens, my material tends to buckle in the center causing the blade to lightly score the prints when it moves from side to side. My question is I have adjusted the tool height on the “Tool” settings to “High”, is there any long term problems that may develop to the head if I leave this as default? After setting it to high it doesn’t scratch the material anymore. I just wanted to make sure I didn’t cause damage to the head tool from leaving it on high. Hopefully you guys can shine some light on me ! Thank you in advance!!! Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted February 15, 2022 I'm going to wait on skeeter for this one - never heard of the carriage height being adjustable - but the buckling is a common knowledge issue with that model Share this post Link to post Share on other sites
JonaDoom 0 Posted February 15, 2022 Yeah I haven’t seen this on older models either. I read on the manual that it was meant for use with thicker medias. Here’s a screenshot of the menu settings and the tool height. It really does help with the buckling and besides the taping a cleaning swab to the head this seems to be the only solution for me to this issue. Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted February 15, 2022 having owned a dozen graphtecs - I have NEVER seen vinyl buckle on a graphtec until the ce7000 series - 1 Share this post Link to post Share on other sites
