Glass Blaster 3 Posted October 23, 2021 Hi, my Creation PCUT is identical to the USCutter LaserPoint and has a worn cutting strip that I need to replace. I can't seem to find the correct part as any replacement strips all appear to use double sided tape whereas mine sits in a groove without double sided tape or glue. Does anyone know where I can purchase a new strip or is there a suggested modification as in purchase a generic cutting strip and attach double sided tape to that? Any help or suggestions would be much appreciated. Googling hasn't helped. Thanks in advance. Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 23, 2021 Have you attempted to flip it over? Share this post Link to post Share on other sites
haumana 1,220 Posted October 24, 2021 https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20211023162452&SearchText=pcut+cutting+strip Share this post Link to post Share on other sites
Glass Blaster 3 Posted October 24, 2021 23 hours ago, slice&dice said: Have you attempted to flip it over? I did think of that as I was removing it but "No" because the profile doesn't allow me to; see attached photo. Share this post Link to post Share on other sites
Glass Blaster 3 Posted October 24, 2021 20 hours ago, haumana said: https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20211023162452&SearchText=pcut+cutting+strip Thanks for the link however I have seen those & the strips on eBay but can't find one that matches mine Someone has the answer, I just haven't found it yet. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 24, 2021 How old is your cutter? Possibly contact the Creation company. Share this post Link to post Share on other sites
haumana 1,220 Posted October 24, 2021 Have you turned the strip around? Not upside down, but pull it out, and put the right side on the left, and the left on the right. That's what I did for my LaserPoint to get more mileage out of the strip. Share this post Link to post Share on other sites
haumana 1,220 Posted October 24, 2021 A little Google will go a long way. https://www.cutterpros.com/creation-vinyl-cutter-ptfe-cutting-strip Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 24, 2021 The GlassBlaster guy apparently didn't put in the right search terms, because yesterday in the first post he said "Googling hasn't helped." Anyway, for $6.49 that should solve the issue he was having, and he's good to go for a few more years. Share this post Link to post Share on other sites
Glass Blaster 3 Posted October 25, 2021 4 hours ago, haumana said: A little Google will go a long way. https://www.cutterpros.com/creation-vinyl-cutter-ptfe-cutting-strip Cheers, that appears to be the one although difficult to see the end profile. That certainly didn't come up in my searches maybe because I'm in Australia; I'll contact them to see if they'll post one (or two) out. Thanks again. Share this post Link to post Share on other sites
Glass Blaster 3 Posted October 25, 2021 4 hours ago, slice&dice said: The GlassBlaster guy apparently didn't put in the right search terms, because yesterday in the first post he said "Googling hasn't helped." Anyway, for $6.49 that should solve the issue he was having, and he's good to go for a few more years. Yep. I pretty well gave up all hope until I discovered that it's the same as the USCutter LaserPoint and joined this forum. Share this post Link to post Share on other sites
Glass Blaster 3 Posted October 25, 2021 22 hours ago, slice&dice said: The GlassBlaster guy apparently didn't put in the right search terms, because yesterday in the first post he said "Googling hasn't helped." Anyway, for $6.49 that should solve the issue he was having, and he's good to go for a few more years. US$73; AU$97!! for two delivered to Australia. I'll search a tad longer here; at least I know that they are available. Cheers all. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 25, 2021 So how old is that cutter? Here is the Creation contact http://www.creation-cn.com/en/about/about.php?type=3 Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 26, 2021 Order just one, for AU$50 -- it's a bit high, agreed, but in the grand scheme of things, will get you back into operation and making money with jobs. Better than wasting more valuable time trying to save $30 or so, that's for sure. These days, just be glad they can get the part to you quickly and alleviate your pain. Sometimes, you have to just bite the bullet. Share this post Link to post Share on other sites
Glass Blaster 3 Posted October 26, 2021 On 10/25/2021 at 8:40 AM, haumana said: Have you turned the strip around? Not upside down, but pull it out, and put the right side on the left, and the left on the right. That's what I did for my LaserPoint to get more mileage out of the strip. Unfortunately it' not worth flipping as it's quite damaged at the other end also. I purchased it second hand last year and it has been ok up until now. Share this post Link to post Share on other sites
Glass Blaster 3 Posted October 26, 2021 On 10/26/2021 at 8:06 AM, MZ SKEETER said: So how old is that cutter? Here is the Creation contact http://www.creation-cn.com/en/about/about.php?type=3 Thanks for the link, I've sent them an email, if that fails I purchase one from USCutters OR may try a modification I have in mind. Share this post Link to post Share on other sites
Glass Blaster 3 Posted October 26, 2021 21 hours ago, slice&dice said: Order just one, for AU$50 -- it's a bit high, agreed, but in the grand scheme of things, will get you back into operation and making money with jobs. Better than wasting more valuable time trying to save $30 or so, that's for sure. These days, just be glad they can get the part to you quickly and alleviate your pain. Sometimes, you have to just bite the bullet. It's only a hobby that is paying for itself so I may just bite the bullet as a last resort; retired so I'm in no hurry. Share this post Link to post Share on other sites
Glass Blaster 3 Posted November 10, 2021 Job done for US$5.50 using an 8mm wide strip & 6mm wide 3M double sided tape; the tape sat in the groove nicely. Thanks for all your help & suggestions. 1 Share this post Link to post Share on other sites
haumana 1,220 Posted November 10, 2021 5 hours ago, Glass Blaster said: Job done for US$5.50 using an 8mm wide strip & 6mm wide 3M double sided tape; the tape sat in the groove nicely. Thanks for all your help & suggestions. Where did you end up acquiring the cutting strip? Share this post Link to post Share on other sites
Glass Blaster 3 Posted November 12, 2021 On 11/10/2021 at 11:03 PM, haumana said: Where did you end up acquiring the cutting strip? I needed 1.2 metres this is a 3 metre roll. https://www.aliexpress.com/item/10000001102416.html?spm=a2g0o.productlist.0.0.45ed3f6130sxw5&algo_pvid=eb9993c2-387b-46aa-b203-9a5d2a16c7c0&algo_exp_id=eb9993c2-387b-46aa-b203-9a5d2a16c7c0-9&pdp_ext_f={"sku_id"%3A"12000015814857766"} 2 Share this post Link to post Share on other sites
