EM Designs 1 Posted September 30, 2021 I had to stop in the middle of a cut to adjust something is there a way to resume the cutting process so I don't have to start all over? There is nothing obvious like "start" that appeared on my screen after I hit stop ... help! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 30, 2021 Once you stopped, you have already dropped the info/data. Set up and start again. Share this post Link to post Share on other sites
EM Designs 1 Posted September 30, 2021 Well Crap - Thank you for the reply! 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 30, 2021 Although the answer given by Mz.Skeeter is accurate, I would venture to say that in some isolated cases, there's a workaround available, depending on the design. For instance, if the cut involves all text, you can go back to the original and perform an edit, leaving only what is not cut yet. Then, set the new beginning of your cut (origin) to commence where you left off. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 1, 2021 A Graphtec, you can stop. It has a HOLD button on the Control panel. Then >continue or clear. But if you lift the media handle, you are done.. I noticed the OP was listing under Prismcut. 1 Share this post Link to post Share on other sites
Helmut 4 Posted October 2, 2021 If you have a Prismcut, use the "pause" button instead of the "stop" button. 2 Share this post Link to post Share on other sites
