Hook Solutions 0 Posted August 31, 2021 I have a very simple shape, a half circle. as you can see the cut order is all over the place. I am trying to get this to cut in a continuous path. I have tried to "join" the different line segments, but that does not work very well or not at all. I have tried to change the order and it doesn't work well either. This was drawn in a cad program as an arc, straight line on top and the round the corners. I export as a dxf and import into VE LXi Expert 120 I drew another shape that was a spline, no straight lines or arcs, and it cuts perfect. any idea how to get this to cut in a contininuous path? Share this post Link to post Share on other sites
bikemike 711 Posted August 31, 2021 Cad programs do not make curves. They are made up of a lot of small segments to form the curve. Just redo it in the graphic program. 1 Share this post Link to post Share on other sites
darcshadow 1,641 Posted August 31, 2021 +1, trying to get a cad/DXF file to work on a cutter is a nightmare. 1 Share this post Link to post Share on other sites
kainth.c.s 56 Posted September 2, 2021 On 9/1/2021 at 5:25 AM, darcshadow said: +1, trying to get a cad/DXF file to work on a cutter is a nightmare. Which software are you using mate? I have been using Flexi 10 basic version and importing dxf straight into it. I never had any problems. Share this post Link to post Share on other sites
kainth.c.s 56 Posted September 2, 2021 On 9/1/2021 at 4:35 AM, Hook Solutions said: I have a very simple shape, a half circle. as you can see the cut order is all over the place. I am trying to get this to cut in a continuous path. I have tried to "join" the different line segments, but that does not work very well or not at all. I have tried to change the order and it doesn't work well either. This was drawn in a cad program as an arc, straight line on top and the round the corners. I export as a dxf and import into VE LXi Expert 120 I drew another shape that was a spline, no straight lines or arcs, and it cuts perfect. any idea how to get this to cut in a contininuous path? HI mate Give this file a try on your cutter. See what happens. Do not ungroup the shapes. Hopefully this will cut continuously as a single path memorabillia.ai memorabillia.pdf memorabillia.dxf Share this post Link to post Share on other sites
kainth.c.s 56 Posted September 2, 2021 On 9/1/2021 at 4:35 AM, Hook Solutions said: I have a very simple shape, a half circle. as you can see the cut order is all over the place. I am trying to get this to cut in a continuous path. I have tried to "join" the different line segments, but that does not work very well or not at all. I have tried to change the order and it doesn't work well either. This was drawn in a cad program as an arc, straight line on top and the round the corners. I export as a dxf and import into VE LXi Expert 120 I drew another shape that was a spline, no straight lines or arcs, and it cuts perfect. any idea how to get this to cut in a contininuous path? Use pedit command before saving it as a dxf in autocad. Type pedit>> select any part of the shape.. Click yes if it asks you whether you want to make it as on>>> select Join or type J and then select whole of the shape and press enter. It should be selected as one shape when you select it after that Share this post Link to post Share on other sites
