Cal 393 Posted January 29, 2021 Hello Friends - been quite awhile since I've been on. Life and other priorities, but I hope to get back to doing some vinyl work. Anyhow, I have a project going on with my truck that I would like some input. I am putting up a carpeted sound barrier on the rear wall of the cab. The carpet is a very thin polyester made for doing speaker enclosures and such. Would something like Siser Easy Weed work on this? How about using an iron to apply it with? This is just a one off project for myself and I do not have a heat press. If the iron will not work, would the Siser work if applied with a heat press? TIA, Cal Share this post Link to post Share on other sites
slice&dice 2,469 Posted January 29, 2021 At your local Big-Box Hobbies shops, there's iron-on transfer materials for sale. They will work with even pressure of an iron, carefully, with parchment paper. Do a test area first. 1 Share this post Link to post Share on other sites
Cal 393 Posted January 29, 2021 Thanks Slice, I appreciate it! 1 1 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 30, 2021 Siser SAYS it can be applied with a hand iron, at least the regular non stretch version. If you it's in a non wear location you might get it to stay. You wouldn't be out much. I would never recommend using Siser on any garment with a hand iron regardless of what they say though. 2 Share this post Link to post Share on other sites
Cal 393 Posted January 30, 2021 13 hours ago, Wildgoose said: Siser SAYS it can be applied with a hand iron, at least the regular non stretch version. If you it's in a non wear location you might get it to stay. You wouldn't be out much. I would never recommend using Siser on any garment with a hand iron regardless of what they say though. Thanks Goose. Since it's not a garmet and washing won't apply to it, it might hold up. Reckon we will try it on some scrap first to see what it looks like. 1 Share this post Link to post Share on other sites
slice&dice 2,469 Posted January 30, 2021 We have to see this end result. As the saying goes -- It never happened if there aren't photos! (or videos, even). Speaking of trucks, I wanted to do some heat-transfers onto hats for truckers (ball caps) : If You Can Read This, You're Standing Too Damn Close 2 Share this post Link to post Share on other sites
Cal 393 Posted January 31, 2021 10 hours ago, slice&dice said: Speaking of trucks, I wanted to do some heat-transfers onto hats for truckers (ball caps) : If You Can Read This, You're Standing Too Damn Close I picked up some Siser HTV today and will hopefully practice with a few scraps to get the hang of it tomorrow. 2 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 31, 2021 14 hours ago, Cal said: I picked up some Siser HTV today and will hopefully practice with a few scraps to get the hang of it tomorrow. Just remember to MIRROR the cut. You are cutting on the adhesive side. 1 Share this post Link to post Share on other sites
darcshadow 1,641 Posted January 31, 2021 I don’t know about speaker carpet, but normal carpet will melt pretty easily, made the mistake of trying to iron something on the floor once. since this is a fixed install, won’t be washed and wrinkled like normal clothes, you could probably het away with normal vinyl even. 1 Share this post Link to post Share on other sites
Cal 393 Posted January 31, 2021 6 hours ago, darcshadow said: I don’t know about speaker carpet, but normal carpet will melt pretty easily, made the mistake of trying to iron something on the floor once. since this is a fixed install, won’t be washed and wrinkled like normal clothes, you could probably het away with normal vinyl even. I can speak to this already I think. The way the carpet comes, for some strange reason it is folded and then rolled up... so it had a very noticeable crease down the middle. SWMBO was able to iron it out Even though the carpet is 100% poly, she ironed it on cotton! But it's all good, no damage done. I've watched a couple Siser youtubes, I think we are going to try a few scraps tonight to check for technique and how it actually looks. I've also got a cutting mat (borrowed) coming tonight. I will have to watch a couple you tubes on that too as I've never used a mat yet. Share this post Link to post Share on other sites
Wilson 43 Posted February 1, 2021 You might try the Color Theory Multiverse while you're at it (https://www.uscutter.com/Color-Theory-Multiverse-Heat-Transfer-Vinyl). I haven't tried this yet but it's supposed to apply in 3 seconds to cotton. 1 Share this post Link to post Share on other sites
Cal 393 Posted February 5, 2021 On 1/30/2021 at 10:19 AM, slice&dice said: We have to see this end result. As the saying goes -- It never happened if there aren't photos! (or videos, even). Here you go Slice. The wife ironed them on today and we are both pretty happy with the results. After this pic I attached the carpet to the backer board with some contact cement and it is airing out the rest of today and overnight before I mount it in the truck. Maybe it was beginners luck, but it was a pretty neat little project. Unfortunately, wifey is now stoked about doing some T shirts for her nephews! Oh well, they will be cheap birthday presents this year, there is that 3 Share this post Link to post Share on other sites
