dvddvd
Vinylmaster not cutting to correct size?
I made a design in Vinylmaster DRS and it tells me its 33.27cms wide that is from the edge of the first letter to the outer edge of the last letter.
I send to cut and it tells me with a auto weed box around it its 35.67cms wide....ok thats fine.
I cut and measure and its cut at 28.50cms ?
Why is it not cutting to the size it tells me the design is? Thanks
Many thanks ive just done it.
It cut a 25cm x 20cms square in the calibration test, mine measured 20cms x 16cms so put the dimensions in and it cuts perfect now
thanks sorted
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
