Mike Bethune 2 Posted January 4, 2020 I just got a new Titan2 Plotter and it came with Vinylmaster cut software. I am using this software only to cut the sandblast stencil, I made the design in Corel draw. I can’t figure out or find online how to cut the layout in sections. An example is let’s say my layout is 68” wide but my stencil is only 24” wide, how do I get it to cut in 24” sections? I use to use flexi on my old plotter but can’t transfer it over and it automatically divided it up for you after you’ve typed in your material dimensions. Any help would be appreciated. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 4, 2020 I have demos of each version of Vinyl Master. The tiling feature which you are referring to, is available in Vinyl Master LTR on up. You can also download the demos and check different features. Higher versions have more features. What do you mean that you can't transfer Flexi over? Why can't you run the Titan on the Flexi computer? Many were using the Copam 2500 driver to run Titan vinyl cutters. (at least they were doing that with the Signblazer software) 1 Quote Share this post Link to post Share on other sites
Mike Bethune 2 Posted January 4, 2020 The plotter with Flexi I have is pretty old, I can’t find the disk, we moved a few years back and must have lost it. I’ll see if I can find your video. Thanks Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 4, 2020 I never mentioned anything about a video. Go to VinylMaster.com and download their demos. Demos are real software to download and try. Quote Share this post Link to post Share on other sites
Mike Bethune 2 Posted January 4, 2020 Ok I downloaded the LTR DEMO and found the tile option right there and it seemed easy enough. So I went ahead and paid extra to upgrade from CUT to LTR I then uninstalled all the programs and reinstalled using my new code and it says it’s LTR but the tile option is not there unless I go to the vinyl spoiler and there’s a box there that you click to tile so I did and it puts a box around the whole image (which stick out way past photo of plotter) instead of breaking it up. This version looks just like the CUT version I originally had...I Don’t understand why this has to be so difficult, if I typed in that my material is 24” but the layout is 40” why it doesn’t automatically break it up. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 5, 2020 Your going to have to contact Vinylmaster. They are your tech support for your software. They can answer your questions. 1 Quote Share this post Link to post Share on other sites
skarekrow 1,842 Posted January 5, 2020 Working from Vm Pro here but I believe its the same for Letter... Select your overwide object to cut (Menu dropdown) > Send to Cutfile> (Select Tab 'Current Page' OR' Selected Items' then >Send ReSelect your object > Edit> Overlap ( Enter a Value... .125 to .250 inch works well) OK > Apply Click "Cut Page" on Menu Bar and a Cut Current Page Module should open that allows you to select which of the Tiles you wish to cut. 1 Quote Share this post Link to post Share on other sites
Mike Bethune 2 Posted January 5, 2020 Well I downloaded the demo again and evidently the PRO version and above are the only ones that do the tiling like I need. I’m not paying that much for a program used only to cut my layout on the plotter. I’ll just buy Flexi 7 for less than $50 Quote Share this post Link to post Share on other sites
skarekrow 1,842 Posted January 5, 2020 Believe you'rere right, Mike.... seems the 'LTR' Version of VinylMaster does not include the Tile Bleed (Overlap) Tools. 2 Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 6, 2020 That kind of sucks when you thought you upgraded to the proper version. You can do it manually but it's a work around. Make two files or however many it takes to do the size you're building. You can cut the design into parts but there needs to be some overlap so you have to allow for that. You must be doing some SERIOUS blasting to be that big. 1 Quote Share this post Link to post Share on other sites
Mike Bethune 2 Posted January 6, 2020 Wildgoose Yes been making sandblasted and hand carved signs for over 30 years, do some really large signs for entry way signs for subdivisions. In fact the largest I’ve made was 4’x32’ and 8’x16’ all at the same subdivision, But mostly average around 3’x5’ 15 hours ago, Wildgoose said: That kind of sucks when you thought you upgraded to the proper version. You can do it manually but it's a work around. Make two files or however many it takes to do the size you're building. You can cut the design into parts but there needs to be some overlap so you have to allow for that. You must be doing some SERIOUS blasting to be that big. 2 Quote Share this post Link to post Share on other sites
Mike Bethune 2 Posted January 7, 2020 Thanks Skarekrow Quote Share this post Link to post Share on other sites
