prevel 0 Posted December 26, 2018 I have vinyl master LTR. When I try to break a curve it automatically rejoins the curve. For example if I type a letter and turn it into a curve, I cannot break the curve, but if I hand draw a shape and join it then I can break it. Also will not let me break a shape I have auto traced from a imported image as well. Thanks for the help Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 26, 2018 Have you tried to "ungroup" the design first? Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted December 26, 2018 I think you're having the same issue I had, and I thought I had it figured out, but now I can't do it. Here's the posting where I asked my question. The break curve thing doesn't seem to work as you would expect it to. Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted December 26, 2018 SOme more playing around and I figured out my problem. In wireframe mode the break curve joins the two break points with a straight line. However if I use wireframe fill on the shape, I can truely break the curve. Might give that a try and see if it works for you. 1 Quote Share this post Link to post Share on other sites
prevel 0 Posted December 26, 2018 1 hour ago, MZ SKEETER said: Have you tried to "ungroup" the design first? yep tried that Quote Share this post Link to post Share on other sites
prevel 0 Posted December 26, 2018 ok ill give the wire frame fill a try Quote Share this post Link to post Share on other sites
prevel 0 Posted December 26, 2018 1 hour ago, darcshadow said: SOme more playing around and I figured out my problem. In wireframe mode the break curve joins the two break points with a straight line. However if I use wireframe fill on the shape, I can truely break the curve. Might give that a try and see if it works for you. worked thank you Quote Share this post Link to post Share on other sites
