Scratchthejeepguy 77 Posted May 22, 2018 My wife has a hair salon and it's very busy. I'd like to display a bunch of stickers on some sort of flat sheet that can be easily picked up, moved and looked at. I tried using one of those white foam boards but there's just a little bit of texture to it and the vinyl looks just barely "rough". I even tried some bare steel and it looks better but it still has some texture. I'd like to use something super smooth like glass, but I'm concerned about it breaking, and I'd like it to be double sided. What do you use? Share this post Link to post Share on other sites
ShaneGreen 131 Posted May 22, 2018 Sheets of coroplast. Lightweight, smooth, relatively cheep and holds up to handling. http://corrugatedplastics.net/ Share this post Link to post Share on other sites
slice&dice 2,450 Posted May 22, 2018 Uh, coroplast is not smooth. It has ridges/bumps. I would use standard polystyrene sheet or foam board faced with polystyrene. 1 Share this post Link to post Share on other sites
ShaneGreen 131 Posted May 22, 2018 Slice&Dice, you're right, "smooth" probably wasn't the right word to use. It has the long lines from the ribs, but the surface has no other texture so the vinyl adheres really well. From 5 feet away it you don't really notice the corrugations unless you're looking for it. 1 Share this post Link to post Share on other sites
Sue2 920 Posted May 23, 2018 A white aluminum sign blank would work well. Sue2 1 Share this post Link to post Share on other sites
Scratchthejeepguy 77 Posted May 23, 2018 Thanks all. I have some aluminum sheets and coroplast here that I will try. I think I'm going to also try colored plexiglass. Share this post Link to post Share on other sites
julian keller 20 Posted May 23, 2018 I used Lexan (plexiglass) from Home depot. Works well and if you drill holes in the top 2 corners it can be easily hung too. With lexan you can change up the background if you were to hang it and have something different each time. 1 Share this post Link to post Share on other sites
signyouup 178 Posted May 24, 2018 White about a whiteboard? Nice smooth surface and and has a frame. Share this post Link to post Share on other sites
Scratchthejeepguy 77 Posted May 24, 2018 8 hours ago, signyouup said: White about a whiteboard? Nice smooth surface and and has a frame. I'm looking for something with two identical sides to double the real estate. I bought an 18"x24" piece of white lexan and it seems to be fine. I may get a smoked or colored one for white decals someday. Seems to meet all my requirements so far and is very smooth. Share this post Link to post Share on other sites
julian keller 20 Posted May 25, 2018 13 hours ago, Scratchthejeepguy said: I'm looking for something with two identical sides to double the real estate. I bought an 18"x24" piece of white lexan and it seems to be fine. I may get a smoked or colored one for white decals someday. Seems to meet all my requirements so far and is very smooth. Fpr white decals the smoke would look good. They also make a midnight black too, at least they used to. Share this post Link to post Share on other sites
