Kristy 0 Posted May 13, 2008 I'm looking for a small desktop size cutter under $500.... I've heard good and bad ........ I would just like opinions on the Craftrobo cutter? Is it worth buying? Any know problems or limitations??? Share this post Link to post Share on other sites
haumana 1,221 Posted May 14, 2008 There are several members here who consider the 24" and at times the 36" as a "desktop" cutter. What are the biggest thing you think you'll be needing to cut? Share this post Link to post Share on other sites
Kristy 0 Posted May 14, 2008 Primarily small single letters and 3 letter monograms..... Share this post Link to post Share on other sites
BannerJohn 1,324 Posted May 14, 2008 I had a craft robo once....unless things have changed....the blade and blade holder are one piece...you cannot just pop in a new blade. Cost of blade holder with blade,2 years ago,was $35. Cutting force was adjusted by adding a or taking away a ring from the blade holder. Software was hard to work with. Woudn't import any standard file types. Pinch rollers are NOT adjustable...you have to use 9 inch vinyl or a carrier sheet (expensive) Just my take....US Cutter offers a 12 inch cutter. I suggest it instead of the craft robo. It is a good machine for scrap bookers and crafters. You CAN do sme basic stuff but it's not easy. I could NEVER get it to cut letters the size that the software showed. On the plus side...the CR is made my graphtec,and is a solid machine. Share this post Link to post Share on other sites
nonabelle 5 Posted May 14, 2008 hi kristy, i owned a craftrobo2 for a short while. my issue with it was depending on what ur cutting and how many the machine gets hot and u have to unplug it and wait 5 min before starting this back up every two full pages. and yes the software is somewhat limited but it did get the job done. now they do have a bladeholder that u can drop the blade in but the blades r so expensive. the carrier sheet is nerve wrecking, the contour cutting feature is hit or miss. if ur going to be doing a lot i wouldn't suggest it. but just for a now and then crafter i would say it's okay. i returned my after discovering the pcut and learning all i could do with vinyl. i actually at the time paid more for the craft robo than i did for my pcut24. i hope this helps, and good luck with ur venture. Share this post Link to post Share on other sites
