Guest Chris kukuk Posted April 30, 2017 I believe I have everything set up correctly with my mh871 - MK2 and vinyl master. I've created my own logo and have tried to print it numerous times, I keep having the same issue even whenever I try a different design. Once I believe I have everything complete and where I want it I attempt to begin a cut and everything goes well until it starts repeating the same image over and over it's just tracing and building it up cutting the same line five to six different times. I'm lost and do not know how to resolve this issue I've read numerous threads and I've watched the tutorial videos Quote Share this post Link to post Share on other sites
Camel 7 Posted April 30, 2017 Can you share your cut file with us? Sounds like you have multiple layers that are cutting. Quote Share this post Link to post Share on other sites
Guest mutiple passes? Posted February 6, 2020 have you gotten any responses to this issue? Quote Share this post Link to post Share on other sites
haumana 1,185 Posted February 6, 2020 21 minutes ago, Guest mutiple passes? said: have you gotten any responses to this issue? If this is happening to you, make sure you don't have multiple layers copied on one another. 1 Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted February 8, 2020 Repeat cutting over the same cutfile is usually because of the following reasons: The artwork has been duplicated i.e. there is a perfect copy of the artwork on top of itself. By using the Object Manager from the Design Center (right side of program) you can see all the objects. Also, select the artwork and press delete, if it remains then there was a duplicate and there maybe more than one. This can happen when artwork is selected and pressing the + key or Duplicate button from the toolbar. Passes in the Send to Cut module has been set to 2 or more. Some cutters have an option to Repeat cut. Removing duplicates, settings passes to 1 or setting Repeat cut off should resolve this issue. 2 Quote Share this post Link to post Share on other sites
