Darius 0 Posted March 9, 2017 Don't know hot to use just starting any in put on if I have to hook r232 and USB together or optional Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 9, 2017 could you tell us what cutter you have? did you install the drivers for the cutter and the usb chipset if you are using the usb? if using serial are you using the cord that came with the cutter. more info needed for any real advise Share this post Link to post Share on other sites
darcshadow 1,626 Posted March 9, 2017 You only use one or the other, USB or serial, not both. Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 12, 2017 I'm kinda surprised that Darius only posted one question and has encountered no further concerns or problems with his vinyl cutter. For a newbie, he's off and running, which is great to see. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 12, 2017 actually slice if you look at his profile he never logged back on from the post 11 minutes after joining the forum. so not sure if he called support or just figured it out or went out partying but he never logged back in to read what was suggested - we have had lots of hit and runs over the years 2 Share this post Link to post Share on other sites
