tomb321 2 Posted April 27, 2008 I'm having a problem with jogging the cutter in Cut a Print. It's not jogging at all. I am able to cut a mask by going straight to the Cutter, but I am trying to weed and cut a heat press transfer. 6.0.21 SB Elements Serial cable connection. Any help would be appreciated Thanks, Tom EDIT: I guess waiting an hour or 2 works. Wierd, it's working now. Share this post Link to post Share on other sites
SmallSigns 23 Posted April 27, 2008 I ran into that -- make sure your cutter says "Waiting" on the display - if not you may need to turn it off and back on (just my fix) Once I do that it will say waiting and the jog will work. Hope this helps Share this post Link to post Share on other sites
routesmith 0 Posted April 28, 2008 Agreed, I ran across that too, I reset my whole computer and cutter (probably not necessary) Wayne Share this post Link to post Share on other sites
