JAZZTONER 0 Posted July 15, 2015 I need help, did the grounding procedure, anti static wipes, send cuts with and without knife, new serial cable, no carpets. Sometimes not recognize serial cable. Waiting for the keyspan adapter. How do I know is the motherboard is broken, driver failure??? Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted July 15, 2015 Great idea for the Keyspan Adapter, You did purchase the Tripp Lite brand, I hope. It is the only one that will work... That and a Belkin cable work with vinyl cutters. Like this.. http://www.ebay.com/itm/Keyspan-High-Speed-USB-Serial-Adapter-Type-A-Male-DB-9-Male-USA19HS-Tripplite-/111647589631?pt=LH_DefaultDomain_0&hash=item19feb704ff More info might help... What software are you using on what type of computer operating system? Did you follow the set up directions here? http://www.uscuttersupport.com/scseries-vinylcutter-setup.html Share this post Link to post Share on other sites
JAZZTONER 0 Posted July 15, 2015 Hi, thanks for reply... yeah, that adapter specifically... I'm using SCAL 3 PRO that one came in the ebay order. I'm on Macbook pro, Yosemite OSX 10.10.4 Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted July 16, 2015 I don't know anything about Mac,,,Or Scalp. maybe someone else will chime in.. Or you could try the FREE week trial of Signcut. It is for a Mac. You can import your designs there and cut. http://www.signcutpro.com/http://www.signcutpro.com/ Share this post Link to post Share on other sites
Wildgoose 4,200 Posted July 16, 2015 Is this a new machine? Have you gotten any communication to the cutter at all? What mac are you running? If you are trying anti-static it sounds like you are cutting but erratically. Static will only effect you if you are actually moving the vinyl in the cutter (Cutting) which creates the static while rubbing against the machine. Share this post Link to post Share on other sites
JAZZTONER 0 Posted July 16, 2015 It's a Macbook pro (mid 2011). Running YOSEMITE NEWEST version 10.10.4. SCALP 3. SC SERIES 34". KEyspan adapter doesn't work, is not recognized... so frustrating. Hours and hours wasted, money, vynil and adapters... HELP!!!!!!! Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted July 16, 2015 Have you contacted tech support and have them remote your computer to set you up correctly....? That is what they are for... Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted July 16, 2015 Instructions to set up Tripplitte Keyspan adapter to a Mac, And for the most part it is adviseable to reboot you computer after installing drivers, so that it is recoginized. https://support.simulationcurriculum.com/entries/21653963-Macbook-Pro-Tripp-Lite-KeySpan-Model-USA-19HS-interfacing-with-LX200GPS- http://facility.unavco.org/kb/questions/505/How+to+configure+a+Mac+for+a+Keyspan+USB-to-serial+cable Share this post Link to post Share on other sites
Jesse F. 7 Posted July 28, 2015 I would definitely call into Support and get a tech to remote in. On a Mac it's most likely two things. A driver that's out of date or a setting that hasn't been configured properly. Usually it's the BAUD rate that gives you the most trouble. I usually save the Keyspan as a last resort and more often recommend it when a USB port takes a crap. But call in, switch back to your regular USB cable, and I'm sure someone here can get you back up and running. If they get everything up to date and configured and it's still having issues it very well could be a motherboard issue. But leave that to the tech to determine. Good luck! Share this post Link to post Share on other sites
djque 246 Posted August 3, 2015 try the usb straight to machine.go to cutter settings select cut with us cutter. model : SC Conncetion: USB Port: Auto Or USB (Usb will appear when you hook it up) Share this post Link to post Share on other sites
