is3od 0 Posted March 4, 2015 dears,i'm using 3d heat press, and Epson L110 printer.first, the colors in the paper not matching in screen. then i found a color profile and its solved.but the current problem is that the colors shown different after the sublimation (overall color almost green)the color in the paper is correct but in the mobile cover its shoown different.could you please help me in this issue ?? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 4, 2015 sublimation inks will look different on the paper as they change shades with the heat when they sublimate into gas . . . .welcome from the US 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 4, 2015 hows the weather there along the coast? Share this post Link to post Share on other sites
is3od 0 Posted March 4, 2015 the colors in the paper same as in PC.. but after the sublimation using 3d Heat Press its look different in the mobile cover. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 4, 2015 yup - it should look quite different on the paper before heating than what you see on your monitor. - your sublimation ink supplier should also have had icc profiles to alter this for you Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 4, 2015 if it looks like your monitor on the paper something is very wrong Share this post Link to post Share on other sites
is3od 0 Posted March 4, 2015 its very wrong, how can i solve it ?? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 4, 2015 what sublimation inks are your using?did your ink supplier also give you icc profiles for that ink?when printed on the paper the ink should NOT look right to you or anything like on your monitor - it will change when heatedsolve it by using the right profile for your ink - using proper sublimation paper and pressing for the proper time Share this post Link to post Share on other sites
is3od 0 Posted March 4, 2015 i'll check with the supplier and come back to you.. thanks a lot Share this post Link to post Share on other sites
djque 246 Posted March 4, 2015 Actually it suppose to match the screen. Look up sublimation monitor calibration. There is a file you print after that shows you did it right. I posted it on here before. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 4, 2015 Actually it suppose to match the screen. Look up sublimation monitor calibration. There is a file you print after that shows you did it right. I posted it on here before. my finished product matches my screen but never my printed paper 5 Share this post Link to post Share on other sites
GraphxNMore 282 Posted March 5, 2015 my finished product matches my screen but never my printed paper THIS^^^ Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted March 5, 2015 Same here my printed sheet(s) never look like the monitor, until I press them/ bake them depends what I press. Share this post Link to post Share on other sites
