parabellum1130 5 Posted March 3, 2015 is it possible for me to run a sheet of magnet through me sc to cut outline shapes so that I can apply vinyl decal onto it... I recently sent a handful of decals to mayhem , a junior roller derby team and they sold out fast for next time I was going to send a more broadened variety so that it might be a multi use item as opposed to a 1 time and done item... whats your take on it... Share this post Link to post Share on other sites
jaybyrd 3,770 Posted March 3, 2015 You can score the surface with the cutter then break apart by hand. Don't know of a cutter that'll cut then all the way through but I nave done quite a few on my lp2 but I can't on my q75 because everything is steel so the magnet just clings to the cutter so I can't feed it in and out. Share this post Link to post Share on other sites
pshawny 410 Posted March 3, 2015 Yes, I have cut magnet material with my Graphtec. You'll want to use a dedicated blade and experiment with the cutting pressure, blade exposure, and speed. It should cut about 90% of the way through the material, then you press it out with your fingers the rest of the way. If needed, you could double up the shape in the cutting software so it makes two passes. There are different thicknesses of magnetic material, 15-20 mil for indoor use, and 30 mil for use on vehicles. Share this post Link to post Share on other sites
dcbevins 340 Posted March 3, 2015 I've witness a few attempts to put that stuff into a cutter. It never could cut all the way through. In the end, a person with some skills and a blade in hand is what was used. Share this post Link to post Share on other sites
