mmwilson 1 Posted December 13, 2014 Can you import from Signblazer to SCAL? I had to replace my MH refine 721 cutter but can not get it to communicate with signblazer. In device manager it is showing up under other device and does not give a com#. It will cut from SCAL but not signblazer not sure what to do. Share this post Link to post Share on other sites
slice&dice 2,451 Posted December 13, 2014 Hmmmmmmmm, you can reassign a Port (COM#) In Device Manager, right-click the Ports item and choose Properties, then Port Settings, then Advanced, and there is a drop-down available to change the COM. Set it between 1-5. Share this post Link to post Share on other sites
mmwilson 1 Posted December 13, 2014 When I choose properties it does not give the option port settings Share this post Link to post Share on other sites
slice&dice 2,451 Posted December 13, 2014 See this screen shot of Device Manager list ---- you don't have an item for PORTS? Share this post Link to post Share on other sites
slice&dice 2,451 Posted December 13, 2014 Can you import from Signblazer to SCAL? I had to replace my MH refine 721 cutter but can not get it to communicate with signblazer. In device manager it is showing up under other device and does not give a com#. It will cut from SCAL but not signblazer not sure what to do. OK, let's move away from the Ports thing, since troubleshooting Windows Device Manager is causing some difficulty, and the question was How to Import, not how to assign Ports! When viewing your workspace in Signblazer, Select All objects, and then choose EXPORT (file menu) which allows you to produce an .eps vector file. That file should IMPORT within Scalpro. NOTE: If there are texts/fonts, just retype them, since an .eps vector of text is usually not clean. Share this post Link to post Share on other sites
mb20music 760 Posted December 13, 2014 OK, let's move away from the Ports thing, since troubleshooting Windows Device Manager is causing some difficulty, and the question was How to Import, not how to assign Ports! Yes, but you were the one who brought up the "ports thing" in the first place! Share this post Link to post Share on other sites
