VolleyChick 1 Posted October 8, 2014 So weird - the only fonts showing when I click the dialog box are the most recently used fonts. I can't get the list with all loaded fonts. I have not made any changes to my pc or the SB software. How can I get my fonts back? Thanks! Di Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 8, 2014 SignBlazer fonts are found within the sbfonts folder that's located in the same folder as the program. If they aren't in there, just reload the application and the 200 basic fonts will appear where they belong. Share this post Link to post Share on other sites
VolleyChick 1 Posted October 9, 2014 Thanks - I'm not sure what you mean by reload - I closed it, rebooted and still no fonts. I copied from my program files and pasted into the SB fonts folder...still only 8 fonts. Do I need to uninstall and reinstall? Thanks Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 9, 2014 Yes, download and run the installer again. http://support.uscutter.com/index.php?/Knowledgebase/Article/GetAttachment/190/24198 Share this post Link to post Share on other sites
VolleyChick 1 Posted October 10, 2014 Will do, thanks so much!! Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 11, 2014 The suspense is killing me. VolleyChick has now apparently disappeared, as well. Did the fonts return? Only the SHADOW knows. Muawahahahahaha! Share this post Link to post Share on other sites
VolleyChick 1 Posted October 11, 2014 Sorry, had orders to get out today so I just vectored the designs with the fonts. LOL I couldn't take a chance on possibly screwing the whole thing up by re-install and not getting stuff done. I'll do it tomorrow, been a long week and there's a yuengling with my name on it waiting for me! Di Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 15, 2014 ..so...?... Share this post Link to post Share on other sites
skarekrow 1,842 Posted October 16, 2014 Might have been more than ONE Yuengling involved.... ~shrug shoulders~ Share this post Link to post Share on other sites
VolleyChick 1 Posted October 16, 2014 Yes, multiple Yuengling's were involved and apparently I should have had more. I just uninstalled/reinstalled and only have 10 fonts. WTH??? Could there be something I ticked by accident? Very frustrating.... Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 16, 2014 OK, here's my next suggestion ---- There possibly are TWO folders in your Program Files folder. One will say Cutting Technologies and the other will say SignBlazer. If that's the case, just transfer (copy) the hundreds of fonts from one into the other. Share this post Link to post Share on other sites
101LEDs 100 Posted October 16, 2014 Here is one with the SignBlazer 200 fonts in it. http://www.4shared.com/zip/LIi7aa_Zce/SBFONTS.html It was too big to upload on here, but it's mine and safe. Share this post Link to post Share on other sites
VolleyChick 1 Posted October 16, 2014 The fonts look like they are there - in this filepath: program files/SB elements/sbfonts/sbkern. I would attach a screenshot but apparently I can't. Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 16, 2014 The fonts look like they are there - in this filepath: program files/SB elements/sbfonts/sbkern. I would attach a screenshot but apparently I can't. The filepath is incorrect. They should just be in sbfonts. That's it. Move them into there. Share this post Link to post Share on other sites
VolleyChick 1 Posted October 16, 2014 Didn't work. I even deleted the "kern" folder. Still only shows 10 fonts, even if I type in some letters all I get is those 10 fonts. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 16, 2014 You could try this version from UScutter.... It has the fonts....No nag screen and all cutter version. Make sure you delete all of the last Signblazer first before install http://www.uscuttersupport.com/downloads.php Share this post Link to post Share on other sites
VolleyChick 1 Posted October 16, 2014 This is crazy. I uninstalled, re-booted, ran exe on the above file and STILL only 10 fonts. I looked in the files and the sbfonts has a bunch of fonts and a folder called sbkern with a few fonts in it. Is there anything in the settings that would keep me from having access? This is really cray cray. Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 16, 2014 Yes, this is bizarre, for sure. There should also be two small "helper" files within the sbfonts folder ------- fntlst.idx and fntgroup.dbs NOTE: The fntgroup (Font group) feature of SignBlazerElements is not active because it's an advanced "Pro" feature that only is part of the HotShot program. See attached screenshot to see what the Pro version appears like ---- Share this post Link to post Share on other sites
VolleyChick 1 Posted October 16, 2014 Yes, they are in the sbfonts folder. Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 16, 2014 All right, let's try one more thing, select and COPY all the fonts in the sbfonts folder and PASTE them into your Windows System fonts folder -- Share this post Link to post Share on other sites
VolleyChick 1 Posted October 16, 2014 I'm in the middle of cutting a few logo's, will check to see if it works once I'm done.... Share this post Link to post Share on other sites
VolleyChick 1 Posted October 16, 2014 No change, just those same 10 fonts. Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 17, 2014 Makes no sense. Whatsoever. Share this post Link to post Share on other sites
VolleyChick 1 Posted October 17, 2014 I don't even know what else to try, bizarre. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 17, 2014 no back up computer? I can't imagine being without one.... Share this post Link to post Share on other sites
