Blues 18 Posted October 2, 2014 What would you usually charge for something like this two colors red with silver grey metallic outline RTA 651 24" X 48"? Two of them. Share this post Link to post Share on other sites
pshawny 410 Posted October 2, 2014 $65/each, ready to apply, not installed. Share this post Link to post Share on other sites
lablover 218 Posted November 8, 2014 Just because I don't know....I'd be curious how you came up with that figure. I'm starting to have people ask me for stuff and I know I'm low balling myself big time. Share this post Link to post Share on other sites
pshawny 410 Posted November 8, 2014 It was just a quick gestimate. $0.04 per square inch for the first color, then multiply that times 1.5 since it's two colors. Design time and installation would be extra. Share this post Link to post Share on other sites
Sue2 920 Posted November 8, 2014 It was just a quick gestimate. $0.04 per square inch for the first color, then multiply that times 1.5 since it's two colors. Design time and installation would be extra. --- ? ? ? --- That doesn't figure right for small RTA.... I have one right now that is 3.5" x 14" (two text lines) RTA one color. 49 sq. in. Using your figures I should charge $1.96. Can't make any profit there. Sue2 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted November 8, 2014 I charge $4/SF for cast so I would be $64 each so pretty close to the same. I work in 1ft min kind of thing and usually depending on who it's for I have a minimum charge per each of $3 or $4 just because of time spent on any single item. Incidentally I often charge $3/SF for calendared. I include waste vinyl into the equation so assuming the above graphics fit within a 24" roll the $64 would hold true. If I had to jump to 30" rolls due to an actual 24" design the cost would jump to $80 for the 2 color graphic. 1 Share this post Link to post Share on other sites
pshawny 410 Posted November 8, 2014 Sue2, you are correct. Larger stuffs typically gets a better price than smaller stuff. Vinyl is cheap, time is valuable. For your example I would charge $7-8. If doing a bunch of the same design then you could lower it a bit. Share this post Link to post Share on other sites
Sue2 920 Posted November 8, 2014 Okay....that sounds better. I generally charge minimum $10...or else I would have every neighbor within a 10 block radius wanting some sort of "Sticker". For the attached file (one color RTA) I charged $12 which includes the "type-setting". It measures 3.5" x 14". Multiple orders at the same time are usually charged at $6/sq. ft. plus set-up/design fee. Sue2 1 Share this post Link to post Share on other sites
SeeJaysPlace 476 Posted November 9, 2014 I just sold a 2 Color 24x36 for $150 each! a little bit of work weeding and layering the vinyl! and 2 1 color 24x108 for $80 each simple design not much weeded or work to it! Share this post Link to post Share on other sites
