iamandy 20 Posted May 11, 2014 I am trying to put some words across the back of my Horse Trailer. I need advice on the application of the decal. Part of the decal will span the gap between the two halfs of the doors. Should I cut the decal in half, then line it up right to the edge of the door, or should I put the decal up then slit where the doors meet up? I've never done a decal that spans a gap like this, so I'm not sure. Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted May 11, 2014 I install then cut the gap ...make sure the vinyl is pressed in well into the gap after cutting...just thak the edge of your squeegee and run up the gap edge 2 Share this post Link to post Share on other sites
joker 618 Posted May 11, 2014 Could you just space the lettering where the gap s between to letters.. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 11, 2014 same as Dan but clean those edges real well all the way around first 1 Share this post Link to post Share on other sites
iamandy 20 Posted May 11, 2014 Could you just space the lettering where the gap s between to letters.. Unfortunately, the way the logo is, there is no gap between the letters. Otherwise I would do that. Share this post Link to post Share on other sites
