jfronk 3 Posted January 20, 2014 Greetings all I am trying to create some text in a circle there will be two lines one at the top and one at the bottom of the circle, and am having trouble getting the text the same size and fitting in the circle without being distorted. can someone point me in the right direction to complete this task? Thanks in advance Jerry Share this post Link to post Share on other sites
mr300s 1,272 Posted January 20, 2014 Can you post what you want? I usually do it in corel draw or you can go to Sign Blazer type in your text top of toolbar hit text drop down then click on text follow arc and you should be able to get it from there? Share this post Link to post Share on other sites
slice&dice 2,451 Posted January 21, 2014 Text menu -- Text follow arc - Alignment above/below - play around with it until you like the results. Also, you may have to KERN out the text before applying the arc, so the letters don't crash into each other. Share this post Link to post Share on other sites
mb20music 760 Posted January 21, 2014 Here is one way you can do it, there probably is an easier way but this works. http://screencast.com/t/0vvFVO9NUkI 1 Share this post Link to post Share on other sites
TT57 135 Posted January 21, 2014 Jerry, remind us of what program you are using. Share this post Link to post Share on other sites
slice&dice 2,451 Posted January 21, 2014 We are in the SignBlazer Elements zone. By the way, mb20Music, I didn't realize that KERNING could be applied after the text is on the arc. Very cool. Nice screencast, that should be useful to a lot of people. Share this post Link to post Share on other sites
jfronk 3 Posted January 21, 2014 Thanks to everyone that replayed to my post. I am learning a lot here. everyone is very helpful. by the way I am using sign blazer Elements. Trying to learn the software is a new experience for me. Don't have Corel Draw or any of the other expensive software. Just a home hobbyist trying to make a few bucks at craft shows. The videos are a great help, seems like the video shows how its done better than some words. Don.t get me wrong I appreciate all replays and the help. thanks again Jerry 1 Share this post Link to post Share on other sites
lueman 19 Posted January 21, 2014 Youtube is a wonderful thing! Good luck Jerry, I usually set up 2-4 arcs with lettering in each It makes it much easier than trying to do everything in one arc. Start by keeping all arcs the same size then re-size as needed. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 21, 2014 I also make a circle then cut it in half then write on the top and the bottom as separate. It seems to work better. Luemans idea of a whole separate arc would accomplish the same thing. I'm not versed in Sign Blazer but I would expect you will have to convert the text to paths at some point after you have it looking like you want. Live text usually won't just cut unless SignBlazer does it differently. Share this post Link to post Share on other sites
slice&dice 2,451 Posted January 21, 2014 SBE takes care of the conversion to paths automatically. SignBlazer was created for text-direct-to-cut. Easy peasy. Share this post Link to post Share on other sites
Jay2703 704 Posted January 21, 2014 For text top and bottom of a circle, I will make two pieces of text. If I remember, the Clockwise and Counter Clockwise determine top or bottom of the circle. Share this post Link to post Share on other sites
jparent 0 Posted February 8, 2014 Go to distort and select the ARC option. You can then drag the nodes to where you want them. If you want the text to be all the same size drag the center node. Share this post Link to post Share on other sites
