jet1012 1 Posted December 11, 2013 I have a customer who would like her font like this (as shown below) I am using signblazer and wonderging if anyone knows the proper way of doing this to a straing line text. Thanks 1212.bmp Share this post Link to post Share on other sites
darcshadow 1,627 Posted December 11, 2013 I forget where it is exaclty but there should be something along the lines of put text on path. Just draw your wavy line, select your text and the wavy line and do the put text on path option. If SB doesn't have that option, I know Inkscape does. Share this post Link to post Share on other sites
jet1012 1 Posted December 11, 2013 That is what I found online and was looking in SB and did see it, I figured I would have to inscape, but thought I would check to see if there was an option I missed in SB. Thanks Share this post Link to post Share on other sites
darcshadow 1,627 Posted December 11, 2013 I don't have SB with me right now but I could of swore there was something like that. If someone else doesn't chime in, I'll double check when I get home tonight. Share this post Link to post Share on other sites
Jay2703 704 Posted December 11, 2013 Under Manipulate + Distortion there is a Bezier option that will do what you are looking for. 1 Share this post Link to post Share on other sites
BigDon 2 Posted December 11, 2013 I do not believe the "Text to path" option is available in SB Elements. It is grayed out on my copy. You can do fit text to path in CorelDraw, Photoshop, Illustrator, and Inkscape however!! ...and like Jay2703 says! Share this post Link to post Share on other sites
dwp99 283 Posted December 11, 2013 I also don't have Signblazer I use Flexi and it is "text on a path". You draw out a curvy line and with "TOAP" chosen the text will follow the line, then just delete the line and cut it out. Share this post Link to post Share on other sites
mb20music 760 Posted December 11, 2013 Under Manipulate + Distortion there is a Bezier option that will do what you are looking for. Yes, it can be done like this... http://screencast.com/t/CxUCkdEEe 2 Share this post Link to post Share on other sites
