tazzdog 0 Posted December 5, 2013 I have this cranberry swag I will be blasting on a rock. I'm trying to get the two berries that are touching to be separated from each other and the other berry to be not flowing in the vine. (for my sandblasting stencil I can't have the two images combined. they will be different colors painted. I have been messing around in inkscapes with it and can't figure it out.basically I want the berries to hang like the first two berries from the leaves. any help would be soooooooo appreciated. thank you, tina cran.renee.eps Share this post Link to post Share on other sites
mark-s 1,126 Posted December 5, 2013 Hire a pro mark-s Share this post Link to post Share on other sites
MrMopar64 47 Posted December 5, 2013 Not sure if this is what your looking for.... MM64 cran.renee 1.ai Share this post Link to post Share on other sites
skarekrow 1,842 Posted December 5, 2013 I'm thinking this is what you're after? cran.renee_02.svg Share this post Link to post Share on other sites
darcshadow 1,635 Posted December 5, 2013 Hows this? cranberry.eps Share this post Link to post Share on other sites
tazzdog 0 Posted December 5, 2013 Thank you. Any of these will work. I will use it to finish my present, but i'm going to keep messing with it in inkscape so I can figure it out. I appreciate everyones input and help. thank you! Share this post Link to post Share on other sites
darcshadow 1,635 Posted December 5, 2013 What I did in inkscape was to duplicate the image and slide it over to the side. I then node edited it and removed the leaves and first two berries. I then went back to the original and node edited it to remove the berries that needed editing. Next I duplicated the berries and set it aside. I then node edited and removed all but the one berry I was working on. Adjusted the vectors to get the berry to looking the way I wanted and slide it into place with the leaves. I then went back to the berry bunch, duplicated it again slide it to the side and then started node editing the next berry. Repeat as necessary. Share this post Link to post Share on other sites
louis clarke ii 202 Posted December 5, 2013 Here is my try. Cran berry.svg Share this post Link to post Share on other sites
