Twisted Inc. 3 Posted October 2, 2013 sorry for the stupid question but i cant seem to figure out how to reverse these colors. i know there has to be a simple way to do it in inkscape. i have several of these to convert and would like someone to point me in the right direction. thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 2, 2013 I found this online There's a command to invert colours (Effects -> Color -> Negative). This is somewhat limited in what it can handle, but it's worth a try. Share this post Link to post Share on other sites
darcshadow 1,627 Posted October 2, 2013 If you node edit, and delete the 4 corner nodes of the square it will accomplish what you want I believe. Share this post Link to post Share on other sites
Twisted Inc. 3 Posted October 2, 2013 If you node edit, and delete the 4 corner nodes of the square it will accomplish what you want I believe. That worked, Thanks Share this post Link to post Share on other sites
Robert H. Bigart 64 Posted October 2, 2013 Hit your print screen key then load "Irfanview" hit the Ctrl + v key then draw a rectangle around the image then hit the Ctrl + y key then go into Image at the top of screen and hit negative then all channels Bob Share this post Link to post Share on other sites
Rodger 527 Posted October 3, 2013 Are you printing ? If cutting vinyl you would not need to change unless you just want to see what it looks like . Just wondering ... Share this post Link to post Share on other sites
