backercl 0 Posted August 20, 2013 my cutter cuts left to right now right to left and mirror image? how do u fix that? Share this post Link to post Share on other sites
slice&dice 2,451 Posted August 20, 2013 Can you be more vague? Share this post Link to post Share on other sites
xpaperman 719 Posted August 20, 2013 Can you be more vague? I think what Slice is trying to say is, if you could tell us what kind of cutter you have, what type of software your using for starters, someone might be able to help out. Share this post Link to post Share on other sites
backercl 0 Posted August 20, 2013 it use to work right to left cutting starting from the right working left it does the complete opposite now works left to right and cutting a mirror image of my work off the screen Share this post Link to post Share on other sites
backercl 0 Posted August 20, 2013 signblazer elements cutter is ct630 Share this post Link to post Share on other sites
xpaperman 719 Posted August 20, 2013 sounds to me, that it might be in the settings in your software. On your cut screen there should be options on the left side of the screen, check to make sure there is no check mark in the mirror box. 1 Share this post Link to post Share on other sites
backercl 0 Posted August 20, 2013 I have to check mirror option to get it to cut right Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted August 20, 2013 then I would check the menu on the cutter and make sure a mirror setting is not set in there Share this post Link to post Share on other sites
slice&dice 2,451 Posted August 20, 2013 I have to check mirror option to get it to cut right There was another recent thread about this exact problem. http://forum.uscutter.com/index.php?/topic/40594-sc-cutter-cutting-in-mirror/?p=312325 My suggestion was to verify the correct driver was selected. Or, you just might try another driver, even though you've got a Creation Pcut. Share this post Link to post Share on other sites
