GTD 0 Posted March 9, 2007 I just received a Refine MH721 cutter and the computer will not command cutter I am pretty sure I have everything hooked up and installed right. The cutter seems to work we did a test and it worked fine but will not cut anything from the computer. Can someone please help me. Thanks. Share this post Link to post Share on other sites
thredz 1 Posted March 9, 2007 You need to tell us what port you are connected to and what program you are trying to cut from. Share this post Link to post Share on other sites
GTD 0 Posted March 9, 2007 Sorry, first I tried USB, then LPT know I have them both hooked up and still have trouble. I am trying to cut from Signcut. Share this post Link to post Share on other sites
thredz 1 Posted March 9, 2007 Mine is running through the lpt port.You have to make sure that you go to settings and cutter in the signcut program and have the cutter set as the model you are using and the device has to be the same port that you have installed the cutter on. Share this post Link to post Share on other sites
GTD 0 Posted March 9, 2007 OKay I have allready tried that a few times and I still can't get any response. Share this post Link to post Share on other sites
thredz 1 Posted March 9, 2007 You also have to go to file and cut out instead of clicking in the scissors in the tool bar.For some reason that tool doesn't work in mine and some others as well.Have you checked your bios settings and made sure the lpt port is set to ecp? Share this post Link to post Share on other sites
GTD 0 Posted March 9, 2007 Thanks for your patience and help but I can not find the bio setting. I have went to file and tried to cut that way but still will not do any thing. Share this post Link to post Share on other sites
thredz 1 Posted March 9, 2007 The bios is the motherboard internal operating system.It is what tells the computer the display memory and port settings.Wen you restart your computer there should be a message like "hit delete to enter setup".It depends on the computer.Compaqs use f10 instead of delete anothers use f2 it should tell you which key to hit.Once you're in the setup program check the lpt port settings and chan ge them to ecp if they are not set that way.I wouldn't change anything else because a couple of the wrong changes will make it very difficult to bring the computer back up. Share this post Link to post Share on other sites
GTD 0 Posted March 9, 2007 are you kidding me, is there another way we cant afford to take a chance in screwing up or losing our stuff on our computer. Share this post Link to post Share on other sites
thredz 1 Posted March 9, 2007 No joke.If you are worried about doing it then try the usb setup.But I can't help you on the usb.I run mine on lpt and serial ports. Share this post Link to post Share on other sites
GTD 0 Posted March 9, 2007 thanks billy we will try usb, and cross our fingers, or try to trade this unit for some colored markers. kidding Share this post Link to post Share on other sites
MarcelC 5 Posted March 9, 2007 Hello, if you are still having problems with the setup please send us an email at uscutter@uscutter.com with your contact info so we can help you. Generally most people are able to get connected using the setup instructions in this posting. http://uscutter.com/index.php?option=com_smf&Itemid=2&topic=67.0 Share this post Link to post Share on other sites
GTD 0 Posted March 9, 2007 Marcel, When I went into bios under parallel port it gave me three options (output only, bi-directional and epp). I did not find an ecp. Is epp and ecp the same? Share this post Link to post Share on other sites
GTD 0 Posted March 9, 2007 Also, if the paper printer is connected via usb do I still have to remove the printer program (paper)? Share this post Link to post Share on other sites
Jaide 0 Posted June 22, 2007 I am trying to use the parallel port, set BIOS config to ECP, did aa test - it works, but doesn't cut anything else out. Share this post Link to post Share on other sites
kenimes 43 Posted June 22, 2007 Make sure nothing is installed in Printers and Faxes that may be conflicting with your LPT port. You could also try another cable if that fails. Then, if that does not help, you could always try another conneciton like the Serial or USB. Email me directly if you need more assistance kenimes@uscutter.com Share this post Link to post Share on other sites
pjmitchell 0 Posted June 28, 2007 Had a similar problem last week when we got ours. What worked for me was using the cable for the COM port, not LPT, and even then, COM1 didnt' work, but COM2 did. Share this post Link to post Share on other sites
kenimes 43 Posted June 28, 2007 Make sure there are no other printers or faxes installed that may be conflicting with your LPT1 port. You could also try another connection method if available. Share this post Link to post Share on other sites
