banditt2129 25 Posted March 22, 2012 If I cut a couple objects out, as the cutter is going the vinyl rides off to the left of the cutter as your looking at it. I have tried tightening it up, tried raising the vinyl so theres no pressure pulling on it, and I have no clue on how to fix this. It cuts the first couple objects fine, then the cuts get thinner and thinner as it goes on. Any ideas??? Share this post Link to post Share on other sites
tshirtn00b 12 Posted March 22, 2012 try pulling the vinyl you need through the front of the cutter first, then lowering the rollers and finally backing up the vinyl. As it backs up you can watch to see if it will be crooked or not. This process works pretty well. I know this topic has been discussed before, check out the search feature on the main forum page. I'll check it out as well and see if I can find some of the threads that helped me. Share this post Link to post Share on other sites
tshirtn00b 12 Posted March 22, 2012 Here's a couple that may help. You'll come to find out that there are a lot of variables that can come in to play even for an issue that may appear to have a simple fix. http://forum.uscutte...%20it%20%20cuts http://forum.uscutte...__1#entry238901 Share this post Link to post Share on other sites
banditt2129 25 Posted March 22, 2012 Thanks for all you help tshirtn00b Share this post Link to post Share on other sites
bigmax 166 Posted March 23, 2012 one thing that I found on my US CUTTER S C cutter,. I kept having the same problem when using the S C cutter.I have been using the NH 721 standand if the cutter is not 'SQUARE' with the stand , the vinyl will "track" to one side. You may want to check the vinyl in relation to cuutter itself. Just my 2 cnts. Share this post Link to post Share on other sites
Hummer 21 Posted March 23, 2012 Read the post with "Grace"...you guys rock! Truly heartwarming and very patient and knowledgeable...thanks Share this post Link to post Share on other sites
