Zombie 1 Posted September 2, 2011 Using Flexi 8.2 and I have a eps file from "Go Media" with several designs on it and I only want to use one but unless I click the select inside and go back and forth deleting objects one by one I can break it apart to use the encasing select tool. You might be able to see by the picture what I mean. Share this post Link to post Share on other sites
mark-s 1,126 Posted September 2, 2011 ungroup, capture the one you want,-copy-new-paste. mark-s Share this post Link to post Share on other sites
Zombie 1 Posted September 2, 2011 Not able to ungroup. it's darkened out. see pick. I can post go media file if anybody wants to try. Share this post Link to post Share on other sites
roxanneupnorth 106 Posted September 2, 2011 Use the "group selection tool" in your graphics program..... Share this post Link to post Share on other sites
Zombie 1 Posted September 2, 2011 Not sure where that is can you explain? Share this post Link to post Share on other sites
roxanneupnorth 106 Posted September 2, 2011 What graphics program so you use?....I use Illustrator and it is the arrow with the + sign..... Share this post Link to post Share on other sites
Zombie 1 Posted September 2, 2011 This is posted in the flexi sign area so I use flexi sign. Share this post Link to post Share on other sites
roxanneupnorth 106 Posted September 2, 2011 Sorry I can not help then... Share this post Link to post Share on other sites
Zombie 1 Posted September 2, 2011 Here is the file if anybody can help me figure it out. gomedia-tribals.zip Share this post Link to post Share on other sites
roxanneupnorth 106 Posted September 2, 2011 Try this.... gomedia-tribals Converted.zip Share this post Link to post Share on other sites
Zombie 1 Posted September 2, 2011 Nope same thing in flexi. What are you working with? Share this post Link to post Share on other sites
roxanneupnorth 106 Posted September 2, 2011 There must be some sort of break apart tool in Flexi.... Share this post Link to post Share on other sites
Zombie 1 Posted September 2, 2011 Yes but is is not highlighted and not usable. What are you using and how did you do what you did? Share this post Link to post Share on other sites
roxanneupnorth 106 Posted September 2, 2011 I use Illustrator.....All the object were ungrouped when I opened it so it must be something to do with settings in Flexi.... Share this post Link to post Share on other sites
Zombie 1 Posted September 2, 2011 Your right I opened it it AI and it was. Now to figure it out in flexi. Share this post Link to post Share on other sites
roxanneupnorth 106 Posted September 2, 2011 Save each design as a separate file and import into Flexi.... Share this post Link to post Share on other sites
Zombie 1 Posted September 2, 2011 Looks like how I will need to do it until I can figure this out or if someone else knows. Thanks! Share this post Link to post Share on other sites
Zombie 1 Posted September 2, 2011 Just figured it out myself. There is an "unmask" option in flexi so do that and delete the background then it works like in AI. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 2, 2011 I'm using CS2,, I just resaved it in Illy, as an .ai file... imported it in to Flexi and ungrouped it. Share this post Link to post Share on other sites
ehmsodef 0 Posted December 16, 2011 No need to import or export, try COPY from corel then paste it on Flexi better if you make HAIRLINE first before copying. Share this post Link to post Share on other sites
