Zombie
eps question
Using Flexi 8.2 and I have a eps file from "Go Media" with several designs on it and I only want to use one but unless I click the select inside and go back and forth deleting objects one by one I can break it apart to use the encasing select tool. You might be able to see by the picture what I mean.
post-1020-0-59635400-1314991232_thumb.jp
Not able to ungroup. it's darkened out. see pick. I can post go media file if anybody wants to try.
post-1020-0-75837400-1314992805_thumb.jp
Yes but is is not highlighted and not usable. What are you using and how did you do what you did?
Looks like how I will need to do it until I can figure this out or if someone else knows. Thanks!
Just figured it out myself. There is an "unmask" option in flexi so do that and delete the background then it works like in AI.
No need to import or export, try COPY from corel then paste it on Flexi better if you make HAIRLINE first before copying.
