tsmart 0 Posted March 19, 2011 Hi how do i get my flexi to stop the plotter from going back to beginning of cut once job is done? I know it is a setting in flexi as when i use to cut with artcut years ago it never did this but once upgraded to flexi it always rolls back to begnning where it started, annoying! Cheers! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 19, 2011 Hi how do i get my flexi to stop the plotter from going back to beginning of cut once job is done? I know it is a setting in flexi as when i use to cut with artcut years ago it never did this but once upgraded to flexi it always rolls back to begnning where it started, annoying! Cheers! after you get the CUT/PLOT screen, going into options or advanced options, at the top of your screen, look for ADVANCE AFTER PLOT and check it. Share this post Link to post Share on other sites
tsmart 0 Posted March 19, 2011 It's already checked mate, and has been all that time! or should be unchecked you mean? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted March 19, 2011 It's already checked mate, and has been all that time! or should be unchecked you mean? It depends on the cutter. Some cutters don't recognize the command. I know my refines didn't. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 19, 2011 It depends on the cutter. Some cutters don't recognize the command. I know my refines didn't. well like John says, doesn't work with all cutters. Mine works as checked. Share this post Link to post Share on other sites
stetson5331 80 Posted March 20, 2011 Hi how do i get my flexi to stop the plotter from going back to beginning of cut once job is done? I know it is a setting in flexi as when i use to cut with artcut years ago it never did this but once upgraded to flexi it always rolls back to begnning where it started, annoying! Cheers! I use Flexi 10 Pro..The only time mine goes back to the start is if I have a sheet in to cut a scrap and I am contour cutting..Mine doesnt do that if I have a roll in cutting multi things.. stetson5331 Share this post Link to post Share on other sites
tsmart 0 Posted March 27, 2011 ok thanks guys so it is definately cutter not recognizing command then Share this post Link to post Share on other sites
