theiss2200 0 Posted March 15, 2011 Everything I cut through Sign blazer it makes this extra box around the whole image. Anyone know how to get rid of this at all? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 15, 2011 Everything I cut through Sign blazer it makes this extra box around the whole image. Anyone know how to get rid of this at all? you can make sure all your weeding lines are turned off. Share this post Link to post Share on other sites
roxanneupnorth 106 Posted March 15, 2011 Is it a weed border?....If so, there should be a way to turn it off... Share this post Link to post Share on other sites
Rodger 527 Posted March 15, 2011 Those options are in the cut screen on the lower left . Share this post Link to post Share on other sites
theiss2200 0 Posted March 16, 2011 what part on the cut screen? I can't seem to find it at all. I see the one for the easy weed but nothing about the box around it. I have tried it both checked and not checked for te easy weed. Let me know Thanks Share this post Link to post Share on other sites
Rodger 527 Posted March 16, 2011 what part on the cut screen? I can't seem to find it at all. I see the one for the easy weed but nothing about the box around it. I have tried it both checked and not checked for te easy weed. Let me know Thanks All the way on the bottom left . Choices are ; # 1 weed all , # 2 weed each copy ( it sounds like this is what you have going on ) , # 3 easy weed & # 4 power weed . I only use " weed each copy " when I use any . Share this post Link to post Share on other sites
theiss2200 0 Posted March 17, 2011 so does it do it to you when you use "weed each copy"? Share this post Link to post Share on other sites
plane 0 Posted September 18, 2011 CUTTER > CUTTER SETUP > UNCHECK 'TRIM TILES' Share this post Link to post Share on other sites
